I retrieved this code by turning the TV on, then off, and immediately pressing and holding the menu and input buttons for about 5 or 6 seconds. I did this three times to verify the code because I've not seen any error codes of "3" listed for this TV. The power light comes on, blinking three quick times pause then once. It does this repeatedly for about five times, then ceases.
SOURCE: Mitsubishi model Wt-46807 Power shuts
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
