Question about Mercedes-Benz Vehicle Parts & Accessories
1985 german mercedes hydralic control box diagram
Diagram of the hydralic lines
Posted by michael britton on
dan lincoln
    Novelist:
  • 157 Answers
Is this an abs unit??? is your car a 190E ??? i have the haynes manual checked out right now from the public library... i can look it up and describe it to you...?
Posted on Nov 19, 2013
89 300 e mercedes cranks over but wont start
Have you checked that it is getting fuel????
Slightly undo one or two of the injector lines on the fuel distributor and have someone turn on the ignition while you slightly depress the disc from the airflow-meter box. If there is no fuel coming up than you have a fuel problem. That can be electrical, faulty fuelpump, the little control box that is bolted to the fuel distributor called electro-hydralic-actuator or even the fuel distributor itself.
Simply a process of elimination.
Fuel
Spark
etc.
Hope this helps
Apr 07, 2013 | 1989 Mercedes-Benz 300-Class
I NEED A FUSE BOX DIAGRAM FOR A 1986 MERCEDES 300SDL
The fuses are identified on a card attached to the inside of the fuse panel cover. A spring clamp holds the cover in place. The fuses are available wherever German Auto Parts are available. Volkswagen - after market fuses seem the most plentiful. They are color coded .. replace same for same. For example on a 84 300SD fuse 18 controls the Power Windows LF & RR & is a 16 AMP. Fuse 5 is a 25 AMP for the seats. A fuse burns out because their is a problem .. for example .. a slight rear end crash could short at tail light socket & crush the bulb .. Fuse 1 an 8 AMP fuse would blow .. this would also cause you to lose your taillights . warning system & Instrument illumination , as they all share the same circuit. a blown fuse .. melts.
Jan 23, 2012 | Mercedes-Benz 300-Class Cars & Trucks
Convertible top not going up.
LISTEN FOR HYDRALIC PUMP MOTOR OPERATION IN THE TRUNK AREA..IF YES YOU HEAR HYDRALIC PUMP MOTOR RUNNING MAKING A NOISE.CHECK HYDRALIC PUMP FLUID LEVEL BY REMOVING THE SCREW TYPE CHECK PLUG.PLACE RAGS UNDER THE CHECK PLUG.AND UNSCREW REMOVE THE CHECK PLUG. FLUID SHOULD BE 1/4 INCH BELOW THE CHECK PLUG HOLE.IF FLUID IS LOW ADD FLUID UNTIL FLUID LEVEL 1/4 INCH FROM THE PLUG HOLE.IF HYDRALIC FLUID WAS WAY LOW YOU NEED TO BLEED AIR OUT OF THE SYSTEM.MAKE SURE FLUID LEVEL CORRECT.START ENGINE AND TRY RAISING AND LOWER THE CONVERTIBLE TOP USING THE SWITCH.IF TOO MUCH AIR GOT IN SYSTEM.HAVE A HELPER WORK UP AND DOWN CONTROL SWITCH WHILE YOU MANUAL OPEN CLOSE CONVERTIBLE TOP BY HANDS BLEEDING AIR OUT OF SYSTEM.KEEP EYE ON HYDRALIC FLUID LEVEL WHILE BLEEDING THE SYSTEM..LOWER THE TOP AND TURN OFF ENGINE. BEFORE OPENING THE HYDRALIC PUMP FLUID CHECK PLUG BECAUSE FLUID WILL SPRAY EVERY WHERE..IF HYDRALIC PUMP CHECK OUT OKAY AND YOU DO NOT HEAR NO HYDRALIC PUMP NOISE.POWER IS GOING TO HYDRALIC PUMP.EITHER HYDRALIC PUMP MOTOR FAULTY OR FAULTY HYDRALIC PUMP RELAY BEST TO LET MERCEDES BENZ DEALERSHIP CHECK IT OUT...
Apr 30, 2011 | 2005 Mercedes-Benz Mercedes Benz SLK350
1985 mercedes benz 190D, are there anyone out there that can send me a diagram overview of the vacuum lines on the engine. i have 4 to 5 vacuum iines thats not hook up, causing my engine not to turn off....
hello,i already sent you the diagram in fixya...it seems you have a problem in viewing it... so i uploaded it in rapidshare and here is the link to download it....
http://rapidshare.com/files/226590130/function_diagram_of_model_201_190_D_.jpg.html
thanks..you can use a photo viewer preferably Picasa Photo Viewer to see the diagram in high definition...just inform me if you have downloaded the copy...
Apr 27, 2009 | 1985 Mercedes-Benz 190
Hello i have a 1985 mercedes benz 190D, automatic trans. I still have a problem with my vacuum lines. where each of the lines suppose to go on the engine. My engine stayes on when i turn the key off. the...
there should be a vaccum operated selonoid on the injector pump(it's on the drivers side of the engine)check and see if you have a bad/disconnected line there.
Mercedes Benz 1985 190D
hello,hoping this diagram help your problem,
if you try to download this, use picasa photo viewer to open the file...it can give you a high quality zoomed image...inform me if you received,ty
Apr 25, 2009 | 1985 Mercedes-Benz 190
1985 Mercedes Benz 190D
hello,i have a copy of vacuum diagram,what is your trans.,,manual or automatic ,so i could send to you,ty
Apr 24, 2009 | 1985 Mercedes-Benz 190
Vacuum diagram of Mercedes 190D, 2,2
neto 190D: You are asking about a vacuum diaphragm?
I'm going to take a WAG.. Your engine won't shut
down with the key?
If so, he is the way you find out:
In your injection pump, the vacuum diaphragm which kills the engine is the one which has the fitting pointing parallel to the ground.
The vacuum line which serves it is a brown/blue
To check the system, first check for vacuum in the line. Run the engine for a minute or so. Cap off the brown/blue line.
Turn the ignition switch off and then with hose in hand, uncap it and you should hear a hissing sound. If you have a vacuum guage, obviously, use it for the test, you need a minimum of 10 inches to kill it.
To test the pump diaphragm, you can rig a vacuum line to a known vacuum source close to the main "T". Run the engine and with the line connected to the diaphragm, connect it to the good vacuum source, if it kill the engine, the diaphragm is good. If you have a hand vacuum pump it would be more ideal, because you could check the diaphragm for small leaks.
If the diaphragm is bad, it is easy to replace on the pump.
The shutoff diaphragm lists for $86.00
Is my shot in the dark correct?
Even though I am a Nissan Master tech, I also specialize in Mercedes-Benz and specifically Diesels, so if you need help, I'm here. I went through a few Mercedes Schools and have been swinging Iron in Mercedes since the 70's
I might be a little more informative than the public library.
Mar 05, 2009 | 1985 Mercedes-Benz 190
Merc 190e fuel injection problem
If the fuel gets to the distributor but no fuel comes out of the distributor if the airflow disk pushed into the air/fuel mixure body, i suggest you check the electro-hydralic-actuator
53703cc.jpg Its the black box (picture thanks to elproboscis from ebay america) as it controles the flow to the pluger body inside the centre of the distributor and goes from the plunger direct to the 4 outlines.
May 30, 2008 | 1991 Mercedes-Benz 190
Vehicle Parts & Accessories Logo
66 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
