Question about Arcsoft TotalMedia
Arcsoft totalmedia usb digital tv tuner device cannot be detected or is not supported
Robbie Goodwin
    Sergeant:
  • 360 Answers
Did you simply plug it in, or install some drivers or what, please?
Posted on Nov 29, 2017
2 Related Answers
Kym01
SOURCE: Arcsoft Totalmedia 3.5 installing fails
I have Windows 7 64-bit and couldn't install TotalMedia 3.5 It would only get as far as Select Video Device, and give 2 options: > WinFast DTV Dongle Gold BDA Filter > FM/DAB Dongle I downloaded a driver (AF9015 BDA Driver - 9.6.3.1) from http://www.unisupport.net/ Select Video Device then gave these 2 options: > AF9015 BDA Driver > FM/DAB Dongle The first one did the trick. (The second one was possibly there because I have a Kaiser Baas USB FM radio.)
Posted on Aug 06, 2011
Juha
I had same problem (Windows 7, 64-bit, FujiTech DVT PRO USB stick). When trying to search TV channels Windows notifies that TotalMedia 3.5 stopped working.
Workaround: The problem seems to be related only to TotalMedia. I was able to setup TV channels and watch TV with Cyberlink PowerDirector 10 free trial version. This free trials expires after 30 days but I'm planning to purchase it so this is not an issue for me.
Posted on Jan 08, 2012
Device not detected or use by other application
Go to 'Windows Task Manager' (ctrl+alt+del) and click the 'processes' tab and (if possible) stop only devices affected and retry. Be careful not to stop devices/drivers required by windows or any application in use otherwise windows/application will stop working.
If a device is not in use and still not detected or is wrongly reported, get the latest drivers and install them first. You may check device settings and make changes as required. If all else fails and you have the original software, try re-installing it after a proper uninstall.
Feb 20, 2014 | Arcsoft TotalMedia Extreme - Windows for...
Cannot detected the device or use by other application
You can get help at
https://ssl.arcsoft.com/totalmedia-extreme/how-to-use-totalmedia-extreme.html
Arcsoft Totalmedia 3.5 installing fails to my 64bit Win7 computer. Installing stops when program asks country settings.
Jul 27, 2011 | Arcsoft TotalMedia
ArcSoft TotalMedia Theatre 3 issue
Download from Arcsoft the "BD Assistant"and it will tell you where your system is failing the HDCP check.
I had an issue with the LogMeIn mirror driver showing up as my graphics card. When I uninstalled it, my HDCP status was good again. The funny thing is LogMeIn and TMT3 run fine together but only under certain circumstances changing multiple monitors do you get this conflict.
Dec 28, 2009 | Arcsoft TotalMedia Extreme - Windows for...
Mionet unable to detect Lifecam 7000
A camera icon will show up at the bottom of your My Resources in MioNet. If the camera does not appear, then a manual scan is required. To scan for a new camera, go to the MioNet application, select File, then click "Scan for Cameras and new Devices…" MioNet will report any changes in the computer configuration.
If the camera isn't detected and an icon is not available, then there may be two devices interfering with a scan:
1. Built-in webcam: MioNet does not support built-in webcams. This device should be disabled in Windows Device Manager, the computer rebooted, and a new "Scan for Cameras and new Devices…" performed with the USB webcam. Once the USB webcam is detected by MioNet, the onboard webcam can be re-enabled and the computer rebooted.
2. TV tuner card: MioNet also does not support TV tuner cards. This device should be disabled in Windows Device Manager, the computer rebooted, and a new "Scan for Cameras and new Devices…" performed with the USB webcam. Once the USB webcam is detected by MioNet, the TV tuner card can be re-enabled and the computer rebooted.
3. If the camera is being used by another program, MioNet will not be able to detect it. Please confirm no other program, including the camera view in Windows control panel, is not using the camera.
May 24, 2009 | Microsoft LifeCam NX-6000 Webcam
ArcSoft TotalMedia 3
esponser(Zoe) 11/2/2010 1:01:34 AM
Hello Nick,
Thank you for using our products.
Regarding your issue, please try to reinstall your TotalMedia 3.5 following these steps(before that, please make sure you keep the original installer):
Step1: Pull out your device and uninstall from Control Panel -> Programs -> uninstall TM, restart PC
Step2. delete these files/folders:
W7 32-bit OS:
C:\Users\current user\AppData\Roaming\ArcSoft
C:\Users\current user\AppData\Local\ArcSoft
C:\Users\All Users\ArcSoft
C:\Program Files\ArcSoft
C:\ProgramData\ArcSoft\licensedata
W7 64-bit OS:
C:\Program Files (X86)\ArcSoft
Step3: Clean up the registration files:
1).Go to Start menu and click "Run", type "regedit" and press Enter.
2).Delete [HKEY_LOCAL_MACHINE\SOFTWARE\ArcSoft] and [HKEY_CURRENT_USER\Software\ArcSoft].
Step 4: Reinstall TM after rebooting the computer.
Hope the above can be helpful.
Thank you for your understanding and interest in our product.
Regards,
ArcSoft Support
Jan 16, 2008 | Computers & Internet
SIMPLETECH 320GB
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
3,069 people viewed this question
Top Arcsoft Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
