Question about InFocus Projector Lamp for IN24+, IN26+
IN24 Lamp for IN24+ Projector
Being I accidently bought an IN24 lamp for a IN24+ projector and opened the box, thus elimating my chances of exchanging it, I want to know if the operating voltage is the same for the IN24 and IN24+ lamps. I realize and can deal with that the IN24+ is a high wattage lamp and is wired differently.
Posted by billmcmanus6 on
5 Related Answers
Anonymous
SOURCE: infocus IN24 lamp not lighting up
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
Posted on May 06, 2009
imkzru
  • 18 Answers
SOURCE: Lamp resistance and voltage
1. Projector lamps use customized ballasts that ignite the lamp by charging it with a higher voltage in the ignition phase and then dropping down to a lower running voltage once the circuit is created.
2. Projector lamps CANNOT be tested with an AMP or OHM meter. Projector lamps function by igniting ultra-high pressurized mercury vapor across an ARC tube. At the point where the mercury vapor resides there is no conductive electrical material and therefore testing a projector lamp with an AMP or OHM will not work.
Posted on Jul 10, 2009
imkzru
  • 18 Answers
SOURCE: Infocus lamp not firing
more then likely the ballast has gone bad and the lamp is not getting the right voltage to fire. Only other thing you can do is remove the lamp the turn the power on and check the voltage at the connector. This will not check the triggering voltage mine you only the lower operating voltage. But since you have replace the bulb with a known good one I'm betting on the ballast is bad.
Anonymous
  • 23 Answers
SOURCE: LP540 Projector Lamp Does Not come on> it has
It's most likely the lamp is bad or the part that starts the lamp called a ballast is bad. The LP540 model has an issue with the ballast burning out. The ballast is a part that starts or strikes the lamp. The only sure way to test is to try starting it with a known good lamp.
You can check for signs of a bad lamp. Think about how long you've had your projector & estimate the total hours on your lamp. If it's over 500 it very well could be the lamp as they fail at any time. Remove the lamp cover door & pull out the lamp to visually inspect it. Look in good light & use a magnifier if available too check for any cracks or chips in the small bulb & look to see if the round part of the small bulb is covered with a lot of white or if it's not round anymore. If it's very white it means it has a lot of hours on it. If there's any loose glass inside (check by turning the lamp cage in different directions) then the lamp is bad. If it's nice & clear or has only a small white spot it's probably a good lamp.
I repair almost all Infocus models if you need a quote.
Thanks & good luck,
Jim
Posted on Jan 20, 2010
Anonymous
  • 23 Answers
SOURCE: The projector powers on, but the lamp does not
If you want, you can just try a burner from LumenArc. It may be cheaper.
Posted on Jan 21, 2010
Resetting the lamp timer on an infocus in24 projector
To reset the lamp timer on an in24 go to settings, then select Service. The option to reset lamp hours should be in this menu.
I hope this helps!
Projector Lamps Projector Bulbs Projector Parts Projector Repair Servcie
Jun 04, 2014 | InFocus Office Equipment & Supplies
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
Projector keeps shutting down every 20 minutes. Could it be the fan or the bulb? or something else?
look at the lamp and check to see if there is foil tape over the seams on top of the lamp. The top is the side under the top cover of the lamp when installed. If the foil tape is absent, then the heat escaping from the seam is triggering the thermal sensor in the lamp housing causing the premature shutdown. If your lamp does have tape on it then your lamp is probably going bad.
Aug 05, 2010 | InFocus IN24 Multimedia Projector
IN24 Multimedia Projector: Orange light bulb light came on....does this mean ...
if it runs for a few minutes before shutting down, it could be the lamp. check to see if the seams of the lamp that are closest to the underside of the top cover have foil tape covering the seams, if not then this has been known to cause premature shutdown.
May 17, 2010 | InFocus IN24 Multimedia Projector
Can the filter be changed on an InFocus IN24 projetor? If so, how do I do this?
there are no replaceable filters. just blow the dust out of the projector with canned air
Dec 03, 2009 | InFocus Projector Lamp for IN24+, IN26+
Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Nov 09, 2009 | InFocus Office Equipment & Supplies
Infocus IN24 lamp not lighting up
Mar 20, 2009 | InFocus Projector Lamp for IN24+, IN26+
InFocus  Projector Lamp for IN24+, IN26+ Logo
51 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Marvin
Marvin
Richard C Cohen
Richard C Cohen
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
