Question about Luggage & Travel
If I walk for a mile how many calories will I burn?
Posted by wentworth kingsley on
Josephina Smithley
    New Friend:
  • 27 Answers
It really depends on the speed, but on average you will burn about 100 calories when walking a mile.
Posted on Feb 20, 2013
How do I reset the time?
How to Configure Your Omron HJ-303 Pedometer
www.walking4fun.com/.../pedometers/...pedometer/how-to-configure.ht...
When your pedometer first comes out of the box, you'll need to configure it. When youchange the battery, you'll have to reset the time on your pedometer, but the ...
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic Institutionyour pedometer and walk your way to better health. Pedometer Setup ... down theRESET button. Additional ... you'll track steps, time, and miles throughout your daily routine. And, in ... Do the math: 20 divided by the number of steps equals.
How to Reset an Omron Walking Style Pedometer ...
www.livestrong.com > Sports and Fitness
Oct 28, 2015 - Your Omron pedometer is a fitness accessory used to provide a great amount of ... session, including steps taken, time walked, distance traveled and calories burned. ... Do not use the end of a pencil to perform a system reset.
Dec 14, 2015 | Exercise & Fitness
How many calories does a 4.3 mile run burn?
500 to 900 calories depending on your weight and the amount of time it took to run it. If you were running hard and consistent then you would burn more calories.
Oct 12, 2013 | Exercise & Fitness
How many calories do I need to burn to drop one pound of fat?
it is very approximate but one pound of fat equals about 3500 calories. So to lose about a pound of weight in a week you would need to reduce your calorie intake and/or increase your exercise. For example, you could exercise off 300 calories a day and drop 200 calories from your food intake and if you did this for 7 days, you should lose a pound.
Feb 20, 2013 | Luggage & Travel
Can I measure how many calories I'm burning while riding an exercise bike?
In most of the new exercise bikes there is a little computer with a analogic display attached to it which gives you information about how many calories you've burned, how many miles you've ridden, your heart rate, etc.
Aug 09, 2012 | Exercise & Fitness
How many calories can I burn on an exercise bike?
If you cycle for an hour around 15 miles per hour, you willburn about 1400 calories.
Jul 09, 2012 | Exercise & Fitness
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    I have the timex fitness trainer and it is calculating my calories for a man and I need it calculated for a woman. Help!
    Simple! men and women burn calories at the same rate. And the more muscle you have the more calories you will burn to conduct an excersize. And the more fat you have, the more calories you will burn from fat.
    Jun 11, 2009 | Timex Health & Fitness Heart Rate Monitor,...
    Garmin Forerunner 305 miscalculating ascent and calories
    Firstly, the ascent and descent are only approximate, and can be very approximate! This is because it's using GPS to calculate your height above sea level when GPS is really only accurate for position Lat and Long. When calculating height, a very, very small error can lead to a large variation in actual height. You should never use a GPS for height if needed for navigation (ie climbing walking etc) If you need accuaracy you will need to get a barometric altimeter.v
    As for calories, I think you have identified your problem, it's calculating calories on running not cycling. Not sure what the answer is as I don't know what software you are using but if you are using Garmin TC, bin it and use SportTracks. Takes a bit of getting used to but to really get the best out of your 305 this is excellent software and it's free. Any anomolies like your calorie issue/wrong category import can be changed manually plus a whole host of other stuff. Garmin doesn't even let you edit activities - crazy.
    Apr 04, 2009 | Garmin Forerunner 305 Personal Trainer...
    Bad counting
    No, you're not doing anything wrong. I would trust the heart monitor, which gives you a better idea of what YOUR body is doing and not what the AVERAGE body is doing. Most pedometers also cannot distinguish running and walking, which have durastically different calorie requirements. It is most likely calculating the calories burnt if you were walking, not running.
    Dec 01, 2008 | Gaiam Walking Fit Kit Pedometer...
    Luggage & Travel Logo
    50 people viewed this question
    Top Luggage & Travel Experts
    Dave braun
    Dave braun
    Tom Chichester
    ray gallant
    Are you a Luggage and Travel Expert? Answer questions, earn points and help others
