Photography Logo
Question about Photography
Driver for target australia film scanner f100
dj4116
    New Friend:
I own the Target AU F100 film scanner and have the original CD. It has a Driver directory on it, which includes DriverInstaller app and 32 and 64 bit subdirectories. It installed recently on my Win 10 64 bit PC and worked ok, despite being Win XP/Vista software vintage 2010.
Posted on Jun 02, 2020
  • Darcy M Stack
    Darcy M Stack Oct 26, 2021
    Hey, i have an F100 scanner but i dont have the CD, would you be able to send me a copy of the Installer?
I thought I loaded the film in a Nikon F100. The Camera showed the film was moving 1-24 I got to 24 the film re-winded I took it to get developed and The film was clear I just need to know how the load...
Since you managed to close the back of the camera and shoot, you've placed the actual canister into the camera correctly.
What happened is there are a series of pegs on the left side of the camera, or sometimes just a red indication line, that the film must be placed onto. If you don't lay the film onto this, the camera won't pull the film out of the canister when you shoot, but it will rewind it back into the canister correctly when it thinks you are out of shots. This will result in a blank roll of film.
Nikon F100 Lower focusing point cannot be selected, other four can. What would be the most possible malfunction.
My suggestion call Nikon at: Nikon Film 1-800-645-6687
They will be able to tell you if it needs to go in for service; it sounds as though it does.
Nikon f100 film won't advance
We will assume you know how to load the film to the red mark. If the film is not advancing a couple of things could be happening. When you close the back door it is not engaging the film to hold it against the take-up spool. If so then that needs to be fixed. The other thing to check is the left side where the film cartridge goes in, does it turn. If not it is binding the film cartridge. Nikon Film 1-800-645-6687
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Kodak 3000 DSV Film Scanner , Film Scanner Driver drivers need
You have to Change the scanner vendor name to MS7000 and then use the Minolta Twain driver listed on their web site...USA site!! there are no Kodak drivers for this unit other then the application software Powerfilm.NO kodak windows drivers either , it uses ASPI drivers.
2answers
Nikon F100, N90 & N80
"End" can be a message for "film over" or for a film jam in the cam. Did you check for this already?
How do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Photography Expert? Answer questions, earn points and help others
