Question about Yamaha RX-V371 A/V Receiver
HAVE A YAMAHA RX-V371 RECEIVER, NO CABLE BOX AND I CANT GET ANY SOUND FROM MY PHILLIPS HDTV.
I DON'T HAVE A CABLE BOX HOW DO I GET SOUND FROM THE TV. DO I USE ONLY HDMI , AV CABLES, BOTH OR WHAT
Posted by bdavisncgc on
Jerry Radcliffe
    Master:
  • 483 Answers
If you have a coax digital out on your tv, why not use that, you have coax, optical, and hdmi inputs on your reciever, but the easiest, low cost way is the coax
Posted on Mar 07, 2013
5 Related Answers
Anonymous
  • 624 Answers
SOURCE: Yamaha RX-V663 Not Providing 1080 Signal
First let me say that you have stated your problem very well. I completely understand the issue you are having.
I have been repairing a/v systems since they started selling them.
By your description of your problem, it is obvious that you have isolated the problem to the Yamaha.
Despite what Yamaha tech support say's, it is their problem.
I have been dealing with tech support for a lot of different manufacters for many, many years. I repair under warranty over 20 different brands, but not Yamaha. I have repaired plenty of Yamaha receivers but none with this particular problem.
It is not uncommon to find tech support people who don't know as much as they should about their own product.
Since I don't have the instruction manual or a service manual forthis model I can only be of minimal help.
What you can do, if you have your instruction manual, check it over closely for this subject on how to change the settings for the HDMI. If you can not find this particular issue, it is possible that the Yamaha doesn't support 1080i. I would be surprised if it did not, but stranger things have happened.
Another thing you can do if you can still not find an answer to this problem is to take it in to an authorized Yamaha service center.
If you have recently purchased this Yamaha, it will be under warranty. They get at least 1 year. Tell them the problem you are having and if they do not know how to solve it right there on the spot, or give you an answer that satisfies you, leave it with them
to have it fixed. If they are an authorized service center they will have to fix it or get it replaced for you if it is under warranty. It may need a firmware upgrade to the digital board. If that is the problem, then they can do it for you.
Let me know if you need any more help.
Sorry I wasn't more help, but an authorized service center may be your best bet.
Posted on Jun 26, 2008
Anonymous
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
Anonymous
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: My Yamaha receiver model rx-v565 audio is putting
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Posted on Sep 27, 2009
Anonymous
SOURCE: Hi, I have a yamaha rx-v465 av receiver and have
I need a connection Diagram for the RX-V465 Yamaha receiver
Posted on Dec 30, 2009
I cannot figure out how to get sound through my Yamaha RX-V361 from my LG 37CS56 hdtv
Are you using any kind of Decoder or Set Top box to receive your TV signal?
If so you can connect the RCA OUTPUT from your cable or satellite decoder, to the Yamaha inputs. See the picture I have attached for you.
Then when you want to hear the sound from there, select DTV /CBL input on your remote control of the Yamaha receiver.
Or you can locate the SOUND or AV OUTPUT (Red and white RCA connection) at the back of you TV, and connect the cables from there to your Yamaha receiver.9_9_2012_6_50_32_pm.jpg
Sep 09, 2012 | Yamaha RX-V361 Home Theater Receiver
Just bought a Yamaha RX-V371 surround sound receiver and the TV audio signal is cutting out. I am running a Samsung LED TV with a single HDMI cable (sound/picture). I tested a smaller tv with a short HDM...
Settings are not the source of intermittent problems.
"Signal loss" is indicated WHERE? So what's going on upstream at the source? ITS cables are a part of this.
My $.02... I never route any signal unnecessarily to or through a device that doesn't enhance or consume it. Hence, my BEST video from each of my several video sources goes directly to my TV/monitor and my BEST digital audio from all sources goes directly to my AVR.
No problems.
Sep 20, 2011 | Audio Players & Recorders
Hello i have a yamaha RX-v459, and i have an HDTV, can i connect my cable box to the yamaha and the yamaha to the TV and get HD? the Yamaha does not say HDTV, does that matter, or will i still get HD?
Yes, the cable box should/could be treated as any other digital audio device. The video could also be run directly to the TV as it doesn't actually improve from being routed to/through the Yamaha, does it?
The labeling on a given input is irrelevant (except for "PHONO", which is literal and exclusively for a turntable).
May 17, 2011 | Yamaha RX-V459 Receiver
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
Mar 12, 2010 | Yamaha RX-V2500 Receiver
Hdmi connection from receiver to hdtv, with set top cable box and no sound from speakers
Check your HDMI sound settings. You can choose it HDMI sound should go to receiver+speakers or to TV.
It is in menu: Setup / Func. setup / HDMI Audio. Options are: Amp / TV / Amp+TV.
Dec 25, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
Jan 08, 2009 | Yamaha RX-V461 AV Receiver
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Open Questions:
See all Yamaha RX-V371 A/V Receiver Questions
Yamaha RX-V371 A/V Receiver Logo
218 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
