Question about Saws
Where is lock down latch on 10in. pro-tech miter saw
Posted by kathybieck on
5 Related Answers
Anonymous
  • 152 Answers
SOURCE: craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Posted on Jan 13, 2008
Anonymous
  • 5 Answers
SOURCE: 10in sliding compound mitre saw
turn the bevel lock to counter clockwise
Posted on May 29, 2008
Anonymous
  • 313 Answers
SOURCE: Craftman miter saw
should be located at the pivot arm assy where close to the motor.
Posted on Jun 03, 2008
Anonymous
  • 6 Answers
SOURCE: Locking mechanism on miter saw.
Push down on the handle . Facing the saw there is a spring loaded pin on the left rear side , right at the pivot point , pull out on it and raise the handle to the up position.
Posted on Jan 03, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
Pro tech miter saw model No. 7208
Drill broken bolt and use an easy out to screw broken bolt out. It is left hand thread.
Mar 01, 2014 • Saws
2helpful
I have a Pro-Tech table saw Model 4008 and neet a miter gauge assembly. The bar is 5/8ths. Any comparable replacements out there?
I tried all of my sources.
all I can suggest is try running an ad on Craigslist ... or search Pro-Tech there and see what pops up.I've seen them without rip fences , with bad motors etc. but otherwise complete for $30 ...
good luck.
Apr 08, 2013 • Saws
The motor brake on my pro tech miter saw doesn't function. Is there a doable fix ? Also need an owner's manual
The brake on saws like yours are controlled by the switch. They do go bad and are easily replaced if the parts are still available. Your heading says you have a Makita tool but you didn't give the model number. If you go to the Makita home site at:
www.makitatools.com/en-us/Modules/Home/Default.aspx
you can put your model number in the search box and get a parts breakdown and owner's manual if they are still available. Parts are available online at sites like www.ereplacementparts.com where you can also get a parts breakdown but not manuals.
1helpful
Looking for release mechanism on a 10in craftsman miter saw ( borrowed the saw and cant figure out how to make the blade go up
There is a little pin, usually black and usually on the right side near the hinge that you pull out about 1/4 inch. Push down slightly on the handle to take the spring pressure off of the pin so it will be easier to pull the pin out.
Dec 23, 2010 • Garden
1helpful
I need new brushes for my Pro-Tech miter saw
Take out the old brushes, take them to the hardware store, they have a box full of different size brushes, one will fit your saw.
Mar 12, 2010 • Saws
I have purchased a dewalt 718, 12 inch sliding double bevel saw , private sale, saw was only used a couple of times and is in new condition .Checked cutting bevels and found that the left 45 degree does...
The fence may be getting in the way of the arm when you adjust the trunion assembly fully to one side or the other for bevel cutting. Adjusting the fence all the way out away from the trunion assy. should allow full 45deg adjustment. If this is not the case, it could be--even though its only slightly used--that there is sawdust built up enough in the housing to keep the arm from fully adjusting.
While the latch COULD indeed be faulty, it generally should always be tightened/locked so that the trunion assy. is fimly "locked" before cutting as this is designed to keep the saw from shifting mid cut, causing binding, uneven cuts, broken blades, seized bearings, etc.
1helpful
2answers
Can't raise the saw assembly in ordr to cut wood
Search the rear of the saw for a locking latch or pin...
3helpful
Craftsman 10-in. sliding compound miter saw
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
