Question about Water Heaters
Leaking water from top - Water Heaters
Posted by matthew hearn on
Gene Haynes
  • Water Heaters Master
  • 5,391 Answers
1) Copy following link for troubleshooting leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
2) After opening link to identify problem, add a comment and give brand, type and approx age of waTer heater for more possible help.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Feb 20, 2013
Why is rust-colored slime leaking out of top of water heater?
The water heater needs to be replaced. The rust-colored slime indicates that the water heater has a leak.
Rheem 81v40d
Copy following links to identify and troubleshoot leaking water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
When tank rusts out, it will get pin holes, and water will leak out of top.
Replace water heater.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Add a comment
1helpful
Hot water heater has a leak somewhere but not at top where water hoses connected
Leaking water heater because steel tank wall rusted through
Is this gas or electric?
Element leaking on electric heater?
Rheemglas water heater leakage from the top seal
1) You have leaking water heater.
2) I do not know what is meant by 'top seal' since that is not typical water heater part.
Does you product manual show a top seal?
Add comment and describe the top seal and add what it does.
3) Attach a photo.
1helpful
41vr50 leaking at the top connnections
Copy following link for troubleshoot resources:
Replace rusted tank
Prevent rusted tank.
If nipples are leaking, and they did not leak before, then tank has most likely rusted out and needs replacement.
Cause for rusted tank is depleted anode rod.
Inspect and replace anode each 1-3 years.
http://waterheatertimer.org/Replace-anode-rod.html
Water seems to be leaking from the top lid of my ge water heater
Make sure any water valves (Cold or Hot) for water heater are not leaking first. Gate valves may leak at the packing nut over time and drip on top of tank. If water is leaking from the top of the water heater itself the tank is corroded and water heater will need to be replaced.
RJ
2answers
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
1helpful
2answers
Reliance gas water heater 40 capicity, has a leak on the top
Most likely only one of the pipes is leaking but weaping enough to cover the top and indented places near both inlet and outlet. This leak has most likely penetrated all the insulation and is a problem throughout the tank wrap insulation...If you are able to blow air continuously long enough to determine which connection is leaking then fix it. It will likely to take quite a while to dry out all the insulation if the water has migrated down into the tank wrap... If you determine that the insulation is waterlogged, you may be able to drill several small holes in the external cover.
good luck
3answers
GE Profile Smart Water Heater leaking at top/no hot water
could be pressure relife valve as well- you need to tell us where water is comig from exactly in order to solve
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
