Question about Sumvision Cyclone Micro 3 Media Player
How do i put my sd card in media player
I recently bought an sd card to get extra media on my media player. But it doesn't seem to fit in the slot provided and i dont want to force it. I thought it might be the sd card i have ordered so i tried the one from my camera but both times, only about a third of the card will fit in
Posted by Kimberley Yates on
Sock Puppet
    Loyalty:
    Visited the website for 30 consecutive days.
  • 322 Answers
Upside down? Which media player do you have?
Posted on Feb 15, 2018
Loaded 8 g sd card but can not locate the songs when I try to play?
The e250 works with microSD cards, which are limited to 2GB. Your 8GB card is actually a microSDHC card. While it fits into the slot it is electronically incompatible and will not work. More recent Sansa players accept microSDHC cards, but this model is limited to cards 2GB and smaller.
Sorry if that wasn't the answer you wanted to see, but that's the way it is.
The camera says xd and sd compatible but it seems that the card is getting stuck and wont fit into the slot for the card?? any ideas why? i just bought the camera 2 days ago
The camera has one xD slot, and is supplied with an adapter which fits into the slot if you wish to use micro-SD cards. Regular SD and mini-SD cards will not fit.
My sansa player does not recognize a micro sd when its inserted
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
1helpful
Additional SD card memory installed in the card slot
Check to see if it is the proper SD card. while several size ( memory) cards may fit the port the player may only recognise a 2 or 3 gig card.
1helpful
Need help
If you have the ZEN V Plus or any ZEN V series the answer is the same.... No all you get is what you bought…..So if you bought the 2GB unit then that’s all your going to get L ....If you bought another "slot card" for it you could get an adapter for the “slot card” to fit in the top UBS slot but the device will not recognize the extra memory.......sorry to be the bearer of bad news.....but the ZEN V Plus is available in 1GB, 2GB, 4GB, 8GB, and 16GB capacities. I hope this help and please give me a rating......I'm always trying to improve...
cbinny1
2answers
Additional memeory
You might be running into a problem with the new card being a SDHC (Secure Digital High Capacity) card and not just a SD (Secure Digital) card. I have had similar problems with SDHC cards when I put then in older products that have regular SD slots (Photosmart Printer). The cards will still fit into the slots, however the method as to which they are read and written to is different which causes the problem. So, maybe try updating computer hardware drivers or mp3 firmware from the Sansa website. Also, if you can, exchange the 4gb SDHC for a 4gb SD card, this could be a pain in the ****, but this solution should fix your problem definately. Hope some of this helped.
File Explorer won't show SD Card
the PVR-H140 unit doesn´t support the SDHC cards, only the old fasion SD cards are supported, sorry :(
SD memory problems
Try inserting the memory card first, then plug the player into the computer.  Worked for me.
Sumvision Cyclone Micro 3 Media Player Logo
Top Sumvision Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
