Only buttons that work are cancel and delay time
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
SOURCE: I need the reset button sequence for a Kenmore
I had the same problem and this fixed it:
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
SOURCE: Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
SOURCE: No reaction when start button is pushed on Kenmore
you have a bad water valve or bad user interface that's the long control in the front of the dish washer.
model 665.17609301 sn FP3312250
