The printer came up with a paper jam so was cleared however still says paper jam with the paper getting stuck. Then all of a sudden a message came up saying scanner error e-02. The printer is used within a nursery so any help would be great.
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
The ink cartridge is probably not inserted correctly. Unplug the
printer and manually move the carriage to a location where you can take the ink
cartridge out. Remove it and reinsert it, making sure that it is fully located, before
applying the power. Make sure that there is nothing blocking the carriage movement, such as
some remnant of paper.
try to reset the settings in the printer panel inside the printer setup
menu. try to choose the initialize all. then observe your printer
operation. manual for troubleshooting options OR check the manual here : http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14397&prodoid=19302859
