First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
SOURCE: acer aspire 5630 wont boot up
it may be that the harddrive had broked, or is not properly mounted. Try removing it and then reatach it. what operating sistem do u use ?!
also try booting with a linux live cd and see if it can accesc the hard drive, if it cant, than thatşs u're problem. If it can, than u have to find out what PXE-E61 is (what component), and then test it (i presume is the hard drive or the optical unit)
SOURCE: new laptop
Open the hard drive bay and make sure the hard drive is properly seated. close bay
reboot and enter bios to see if hard drive is detected in bios, if the hard drive is detected and still will not boot use recovery console to recover the OS.<ALT><F10>
If the bios does not recognize tthe hard drive, replace hard drive.
SOURCE: acer aspire wont boot after improper shut down
It appears that you deleted some systems files.
You have been unsuccessful with System repair, then you need to reinstall Windows plus all your device drivers (eg. video, audio,LAN etc.) and your programs. If you don't have these drivers then go to a working computer and download them from the computer's WEB download/support site.
You will most likely lose your data in the process of reinstalling Windows, if you are desparate to recover your data, then remove the hard drive from the computer and connect it to a USB hard drive adapter and connect it to a working computer's USB port, this computer will see it as an external hard drive, you can then copy your data onto a CD or USB memory stick.
SOURCE: acer aspire wont boot up only goes to blue acer
you might need to reformat and reinstall the OS for this one... if you want, you can try repairing the OS first using the windows operating system disc and if it doesnt fix it then reformat and reinstall OS...
SOURCE: my acer aspire 5536 turns on and starts to boot up
Restore the pc to original settings without CD:
To activate the Bios utility, press <F2> during POST.
Before performing a restore operation, please check the Bios settings.
1. Check to see if Acer disk to disk is enable or not.
2. Make sure the D2D Recovery setingin Main is Enable .
3. Exit the Bios utility and save changes. The system will reboot.
To start the recoveryprocess:
1. Restar the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process.
3. Refer to onscreen instruction to perform system recovery.
