Question about Activision Call of Duty 4 Modern Warfare for PlayStation 3
My clan tag keeps being disallowed for prohibative text can you tell me why
I am not using bad language or offensive remarks but my clan tag only stays on for approx 36 hours before being removed as having prohibative text.
Posted by Robert Maughan on
Will Bokach
    Prodigy:
    An expert who has answered 500 questions.
  • Activision Expert
  • 537 Answers
It's been flagged as offensive to others, try something less vulgar.
Posted on Nov 06, 2013
Why Is the VLAN Priority Configured on the S5700 Invalid?
Fault Symptom The outbound interface of the switch joins a VLAN in untagged mode. When the remark 802.1p command is configured on the outbound interface, the configuration is invalid.
Cause Analysis The configuration of the S5700(such as S5700-28P-LI-AC)is as follows:
traffic classifier test
if-match any
traffic behavior test
remark 8021p 2
traffic policy test
classifier test behavior test
interface GigabitEthernet1/0/1
port link-type access
port default vlan 10
traffic-policy test outbound
The outbound interface joins a VLAN in untagged mode, so VLAN tags are removed from packets sent by the interface.
Conclusion To apply traffic policy defining remark vlan to the outbound interface, ensure that the interface joins a VLAN in tagged mode.
Jun 22, 2016 | Electrical Supplies
I have been notified that you are going to remove me from facebook for in apprpriate stuff, what did I do?
its usually the using of bad language or deflammatry remarks against an indivisual check your blogs
Sep 03, 2015 | Facebook Computers & Internet
Remove a picture
Angie Where on facebook is this picture and what kind of picture is it? If it is on someone else's page all you can do is tag it and say it's offensive and report it. If it's on yours you should be able to delete it or again if someone else posted it you report it as being offensive and report to proper authorities.
Feb 20, 2014 | Facebook Social Network
Facebook troubleshooting
Depending on the context of the argunment, facebook has certain guidelines for profanity or use of offensive language. Facebook is impartial, so they do not really care who is right or wrong, they just do not want people to fight.
Feb 05, 2018 | Facebook Social Network
I cannot enter a clan tag, it says banned for prohibited text. I never used anything prohibited, how can this problem be resolved?
There is something that you are entering in your clan tag that the system doesn't like. It may not look prohibited to you but it is flagging it for some reason. I would just try a different clan tag as there isn't really a whole lot you can do about it. If you are adamant about using the clan tag you can try to contact technical support. There is a forum located here and you can probably retrieve a phone number from the forum if you wish:
https://activision.custhelp.com/cgi-bin/activision.cfg/php/enduser/std_alp.php?p_sid=4h6balCj&p_lva=&p_li=&p_accessibility=0&p_redirect=&p_page=1&p_cv=&p_pv=&p_prods=0&p_cats=&p_hidden_prods=&prod_lvl1=0&p_search_text=&srch_btn_submit=%C2%A0%C2%A0%C2%A0Search%C2%A0%C2%A0%C2%A0&p_new_search=1&p_search_type=answers.search_nl
font.f1 {font: 12.0px 'Lucida Grande'; color: #000000} I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Activision Call of Duty: Black Ops
My console got banned from playing Call of Duty Black ops for no reason... how do I get unbanned?
First think, were you using the voice chat AT ALL because you may have been reported by a little kid :P.
Do you have and offensive name/emblem/clan tag?
What did the message say when you got banned?
Reply and I may be able to help :)
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Changing front brake rotor on 1995 honda passport
Put the parking brake On and jack up the front of your SUV.
Remove the lug nuts and you will be able to remove the tire and rimm by sliding them off.Remove the spindle bolt located at the center of the rotor using an 36 mm socket(approx).
Remove the two nuts located behind the rotor (one at top and other at the bottom). This will enable you to remove the brake caliper.While removing it be careful that the caliper tube stays straight.
Slide under your passport and remove the 4 bolts behind the hub using an 12 mm(approx) wrench.Pull the hub assembly out and this will remove the hub rotor in some cases if you are using an tool for pulling the hub assembly out or you have to slide the rotor off the hub assembly.
Slide the new rotor into the hub assembly.Reinstall the brake caliper and make sure the caliper tube is not twisted. Replace the spindle bolt.
Nov 14, 2010 | 1994 Honda Passport
About EOF and BOF
Hello Gugukandmiaw
You do not have to use the elseif statement. Maybe this will work.
Greetings Fred Roubos.
With frmPetugasView.Adodc1.Recordset
If frmPetugasView.Tag = "New" Then
.AddNew
!PetugasID = txtInput(0).Text
!NamaPetugas = txtInput(1).Text
!Keterangan = txtInput(2).Text
.Update
End if
If frmPetugasView.Tag = "Edit" Then
.Update
End If
End With
Dec 18, 2008 | Computers & Internet
Activision Call of Duty 4 Modern Warfare for PlayStation 3 Logo
63 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
