SOURCE: Touchpad buttons dead
Most people don't know there is a 5 year warrantee on solid state electronics. or else i found the part on repairclinic.com. I don't know if they will be cheaper
SOURCE: Jenn-Air Gas-Electric Grill Ranfe with Convection Oven M# SVD48600
if possible, squat down in front of the range and put your ear as close to the bottom of the control panel/top of the door when you close it. there is a small motor that pulls the door in when you use the self-cleaning function. perhaps that motor is running all the time? its quite, more of a humm. this could explain why its locking itself. other than that, my convection oven JennAir has a small fan in the back that runs when the oven is on, regular or convections mode. you can see this fan squirel cage in the back wall of the oven. if you were to pull the range out, you will notice (atleast on mine) that there is another much smaller fan on the backside of the range behind the removable metal panel. what the smaller fan is for, i have no idea. so there are two fans, plus if you have the down draft feature, thats 3 total. hope this helps somehow.
SOURCE: remove probe from oven
most electric ovens have a temperature sensing probe inside of them. this is to prevent the oven from overheating and causing a fire. the reason why it's asking you to do that is because it's either dislogged from its place or it need to be replaced.
SOURCE: Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
SOURCE: I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
