Adding film. Changing film
SOURCE: 35mm Film Camera Ricoh XR-2
You can replace it with the available lever.Most of the cameras lever can suit
Posted on Apr 02, 2008
SOURCE: Shutter Release button
Did you try changing the aperture? Depending on the lighting in the area, you may want to change this accordingly, if you put it in AUTO, and you're in a dark room the shutter might not open immediately.
Posted on Sep 14, 2008
SOURCE: film
It's a 35mm camera, so it uses 35mm film (sometimes referred to as size 135).
You can download a manual from http://www.butkus.org/chinon/ricoh.htm
Posted on Feb 03, 2010
SOURCE: I need to convert my manual lens to a digital body. what digital
If you have Ricoh lenses that do not have electrical contacts, you can use the lenses on Pentax digital SLR cameras.
If you have Ricoh lenses with electrical contacts, you can not use them on Pentax digital cameras.
Posted on Jul 14, 2010
SOURCE: Can the 35mm SLR Ricoh
Straightforward answer: no. Everything needs power to work except for the self timer, but even that won't fire the shutter without battery power.
Posted on Sep 12, 2010
