How to trouble shoot trane 80 gas furnce - Heating & Cooling
Posted by Randy Collins on
KD Grayson Heating,Air conditioning & Refrigeration
  • 499 Answers
The 1st thing I do is go to the thermostat and put the Fan switch from Auto to the On position. If the fan operates this proves you have both high and low voltages and the breaker, fuses, transformer etc is functional, this saves one from going to the breakers and air handler often in an attic or roof or basement.
If the fan does not operate then I check for correct power.
Set the thermostat for heat mode and turn the temperature setting well above the rooms temperature. and observe the furnaces sequence of operation.
What you normally expect is upon the white circuit from the thermostat being energized with 24 volts, the induced draft motor will cycle for 30-60 seconds typically to pre purge the heat exchanger, after this purge the induced draft motor has a pressure switch that senses the induced draft operation thus proving the induced draft motors running and alloqw the ignition to begin, either a spark or a HSI, hot surface ignition type.
If you see no bright white light or hear a sparking noise by the burner area this is normal, this will be followed by a trial period for ignition, meaning the gas valve will be energized for a 30 second trial period, during this time the flame rectification proves a flame exists by a DC signal being sent back to the module by the flame sensor or the ground/burner ground.
This DC signal is very weak and easily interrupted and this is why we clean flame sensors and simply re seating wiring will often times correct a situation,
The typical issues are the induced drat pressure switch and the orifice that it's tubing connects to on the induced draft housing.
This port must be reamed to clear carbon and if not will cause a problem such as locking out requiring resetting power or a 5 hour wait for some units,
You need to insure the limits and roll outs are all closed, its all failrly simple if the LED is tellingyou the error as they do today.
how to trouble shoot  trane 80 gas furnce - 6f844a5e-8b48-4d8d-8465-740ad3eb9c87.png
Posted on Jun 07, 2014
1 Related Answer
Anonymous
  • 121 Answers
SOURCE: i need to know where
Trane is very picky about being a Trane dealer before they will even talk to you. But as far as trouble shooting a module there no guides. If the flame comes on then the fan does not shutting down the furnace it could be a fan relay failure or the fan module failure. The modules propose is to allow the furnace time to heat up before bringing on the fan so as to not blow out cold. Or the fan motor it's self could failing
Posted on Oct 03, 2008
TRANE XL80 WATER LEAKING INTO NEIGHBORS GARAGE (CONDO)
Correct me if I'm wrong , but isn't the XL80 an 80% efficiency gas powered, forced air furnace? If that is true, there should be no water coming from anywhere unless rain is coming in the chimney. An 80%er isn't a condensing furnace, so its not condensate. Are there other utilities like a water heater or tank that are in the same vicinity? That is much more likely. XL80 Trane
Jun 27, 2018 | Heating & Cooling
Condensate Pump
no it will cause your furnace not to run at all if the condensate pump fills up
Jan 26, 2014 | Diversitech Condensate Removal Pump
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
Oct 12, 2012 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
Trane AC is not turning on it says E2, what does that mean?
Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
Sep 21, 2011 | Haier Mechanical Air Conditioner HWF05XC7
My suction pressure is 90 psi liquid pressure 360 psi and my temperature ot te vent is 62 degrees f. what ismy problem?
I would say you are overcharged with freon...try dropping some of the gas out... with the proper equipment to recover the gas... it is illegal to vent it to the atmosphere...
You should be looking at 70-8- on the suction and 250-275 on the high side on a warm day and a good load on the the A/C say 75-80 inside temps...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 07, 2010 | Goodman CLQ36AR49 Air Conditioner
Trane air handler model #TWV036B140A Fan wont stop
Sounds like you have a bad fan relay, the fan should shut of within 30 to 120 seconds after t-stat is satsified.
Apr 24, 2009 | Heating & Cooling
Hooking up a used 550 to a new 80% trane UD-R9V,
In this situatioin you'll eed a second transformer 110volt to 24 volt to relay from w to common to operate only when furnace being called for.
Feb 07, 2009 | Aprilaire 550 Humidifier
I need to know where I can find a trouble shooting guide for a Trane mod0944 module for a blower motor (mot09675)
Oct 03, 2008 | Heating & Cooling
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
