Question about Crate Music
GFX-65 Sound cut out - Crate Music
How to reset guitar effects, specifically zoom gfx5 on a factory mode
not sure about the GFX-5, but with zoom you typically hold the 'store' or 'save' button down while powering up the device. Then it'll ask if you want to delete settings or some such...
Jul 13, 2015 | Zoom Music
Only humming or buzzing , no music or sound
Try different cables. That would be the most simple and cheapest fix.
May 27, 2014 | Roland Kc-150 65-watt Keyboard Amplifier...
Yamaha YPT-410 When playing the keyboard, the sound cuts out when playing multiple keys, and then begins again only to cut out again. Does not matter which keys. I have done a factory reset and it did not...
It's probably your keyboard. Some keyboards are limited with it's polyponic capabilities. Some can play many notes at one time, some cut out when it reaches it's limits. Check your manual for specifications.
Aug 25, 2011 | Yamaha Corporation Of America 61 Key...
When I listen to my amp with headphones the sound seems to come and go.
I have a 250 gfx, and I have had the same problem intermittently, I have concluded that the digital fx section is to blame, as it is also responsible for the speaker modelling for the line/headphone jack, and I have also had problems with my fx section.
If you have anything in the effects loop that boosts signal volume remove it, a small boost in the loop gives the power amp in these a nice glassy sound, but seems to be (in my case at least) responsible for the failure of the fx/ emulated line out.
Also check all your leads and headphones cord, try some different headphones if you have them.
Apr 03, 2011 | Marshall Mg50dfx 50-Watt Combo Guitar...
Twin tube amp. power comes on, no sound. replaced tubes, still no sound
Do you have the speakers connected properly?? If so, maybe speaker wiring needs checked.
Feb 19, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
Como resetar o gfx8
zoom GFX-8:
The All Initialize/Factory Recall function is a special function
that lets you reset the GFX-8 to the condition in which it was originally shipped. When All Initialize is performed, all settings of the unit including all user group patches are returned to the default condition. Factory Recall can be used to reset only specific user group patches group to the default settings.
1. Turn power to the GFX-8 on while keeping the STORE key depressed.The display shows "ALL-INIT".
• To perform All Initialize, Continue with the next step.
• To perform Factory Recall, Use the BANK UP/DOWN foot switch and foot switches 1 - 4 to select the patch (from a user group) that you want to return to the factory default condition.
2. Press the STORE key once more.
All Initialize or Factory Recall is carried out.
If All Initialize was carried out,
the unit automatically returns to the play mode.
Note that when All Initialize is executed,
the contents of all patches stored by the user will be overwritten (erased).
When wishing to cancel All Initialize/Factory Recall,
press the EDIT/CANCEL key before step 2.
source: ZOOM GFX-8 User Manual.
Oct 13, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom GFX-8 effects are switching to OFF mode spontaneously
I'd try Axe or Long and McQuade. Phone each one to see who is the Zoom dealer and whether they can fit you in. If they aren't they should be able to recommend somebody. A lot of the guys at both stores are musicians.
Oct 23, 2009 | Zoom Music
Music Logo
35 people viewed this question
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
