Grinding noises during scanning
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
SOURCE: canon pixma mp830 will not scan
I had the exact same problem after moving my printer to a new computer. I realized you need to have MP Navigator on the computer for the scan to work, just the drivers and firmware aren't enough. The other functions do work without it.
So if you don't have MP Navigator on your computer, that should fix it. If you do, I can't help.
SOURCE: MY PRINTER
in the small moniter what the errore you have like E5 - E2- E3 so that we can help you this Errore know you the problem on the printer
SOURCE: Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
SOURCE: Canon Pixma MX850 won't scan - says 'set the pc to start scan'
Do you have more than one PC connected to the scanner? I have both a PC and a Mac connected to it, and I think my scanner is trying to connect to the Mac, which requires image capture software to be installed, rather than the PC. Don't know how to tell it to go to the PC, though...
