Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
SOURCE: How do i reformat C drive and keep my files on sata backup
dis connect the sata cable that attaches the sata hard drive to the pci card and then format c and re install with all the drivers you require for the pci card as well as motherboard drivers, network card drivers etc and then re attach the sata cable that way you dont get confused between which drives its showing if it manages to display the sata drive at boot up.
Posted on May 16, 2009
SOURCE: Primary Master (Samsung HD080HJ/P) Your
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
also you might try
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Jan 18, 2011
SOURCE: can i put a samsung
Unless the motherboard in your system is different from the one shown on HP's site, the answer is no, you can't install the drive. At least you can't install it without additional hardware, which I'll describe in a moment. It looks like this board only has SATA connections for drives, which is becoming more common. So there is no conventional (i.e., old-fashioned) IDE connector for the data cable used by your Samsung drive. There's no place to plug the in the drive.
What you'll need if you want to use a parallel IDE drive is an expansion card like this one. There are many similar cards; I'm just using this one as a sample. The card installs in one of the PCI-E slots on your motherboard, and it provides the IDE connection you need. In addition to the card, you'll need an 80-conductor ATA-133 IDE cable.
With SATA drives, there isn't the master/slave designation since each SATA device has a direct connection to the motherboard. With the parallel cable, you can have two devices connected, so one needs to be designated as the master and the other one as the slave. The master is the drive connected to the plug physically at the end of the cable, and the slave is the middle plug. When you install your Samsung drive, set it for "master" or "single" drive as required. Some drives have a special jumper setting when used alone, while others need to be set as master even if there is no slave drive present. The jumper settings are usually marked on the drive, or you can check at Samsung's website.
Hope this has helped. Thanks for using Fixya!
Posted on Jan 20, 2011
SOURCE: format Samsung HD154UI 1.5TB 1500GB SATA DRIVE LBA 2,930,277,168 SATA Hard Drive
you might have to many programs trying to or accessing your computer at the same time or a virus You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open click start click on my computer you should see your usb drive right click then select format another way is to control panel administrative tools computer management disk management right click on your drive select format
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
when purchasing any ram you should always ask if they can guarantee compatibility first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have a virus also select
or you might need to add more computer ram
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope this helps
Posted on Aug 21, 2012
Jan 28, 2014 | Toshiba s Hdd2h81 640 Gb Internal 5400rpm...
Oct 23, 2013 | Samsung Spinpoint MP4 HM320HJ 320GB 7200...
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
May 08, 2012 | Western Digital (WD3200BEVT) 320 GB SATA...
hope this helps
Jan 18, 2011 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
Mar 19, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Jun 09, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Apr 11, 2009 | Computers & Internet
Mar 06, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Sep 23, 2007 | Biostar P4M800-M7A Motherboard
Jan 27, 2018 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
