The machine stops as soon as the water goes in. It is no more than 2 minutes into the cycle. I suspect my waste outlet pipe may be blocked but there are no fault lights on the door to hint at this. I have to empty the bottom of the machine manually and there is no obvious blockage at the drainage point inside on the floor of the machine.
SOURCE: Inlet/outlet light comes on
Machine is possibly not filling with correct amount of water if this light comes on early in the cycle
SOURCE: Miele G638 dishwasher.
Hi John I have the same problem, the manual says that it is because the water level is to low, this is checked by opening the door after the machine has stopped filling and before it starts to wash, the level should be 4mm above the main plastic filter ring, the level has two settings, these can be adjusted by pressing the start button and the On/Off button at the same time, release the start button and turn the control to economy 45,if the start light does not come on the level is set to normal, to increase level press the start button again and the light should come on, this will give you an increased filling time. it did no help me but it may help you. good luck
SOURCE: My Siemens SE64A630GB does not drain.
Could be the pump or controller has failed if no blockages.
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
