Question about Konica Minolta DiALTA Di200 Copier
Konica minolta c 350 reset error c 0511 - Konica Minolta DiALTA Di200 Copier
5 Related Answers
Anonymous
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
Anonymous
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
Anonymous
  • 13 Answers
SOURCE: Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
Posted on Sep 13, 2009
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
I would like a list of error codes for the Konica Minolta bizhub 350
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C350
Apr 14, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
C0204 error
how do i reset konica minolta c450 machine error 5353
Sep 23, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c-6751 on konica minolta c451
C-6751 CCD clamp gain adjustement error.To reset turn OFF the copier.Press and keep pressed the Utility key and turn ON the copioer and wait for the Trouble reset message appaire on the display.Realease the Utility key and touch the trouble reset then turn OFF the copier.Wait 1 minutes and turn ON.
Mar 14, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error C11A3 Konica Minolta BH 350
solution for error code c11a3 konica minolta bizhub 350 machine
Jul 21, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 - now you are in service mode, - stop 0 C, and there shold be admin pwd
Oct 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta DiALTA Di200 Copier Logo
129 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
