My 2000 hyundai sonata used to get stuck between 3 and 4 gear but after puitting some stop slip in the car it stop doing that but the car putters when slowing down at a stop light and shifting from reverse it bangs really hard but drives just fine other than the puttering. what could be wrong?
SOURCE: Mercedes after shifting to reverse to drive the 1st gear slips
they didn't line the motor up properly now ur transmission is at to much of an angle and it is making it slip
SOURCE: 3rd gear help please!
I have a 2002 Hyundai Sonata and I had the same problem. But mine would always shift into 3rd gear and STAY there until I turned the car off. I took it to a Hyundai dealer and he had to rewire a speed sensor on top of the transmission. Apparently a little animal got up in that tight little spot and gnawed on my sensor wires. The car has run fine since. To make a long story short, it might be your speed sensor on your transmission.
SOURCE: 1st gear slipping at start. reverse and other
Have you checked the trani fluid ?
It could be slipping just enough to notice in 1st gear beause that is the most resistance..
A slip is a slip..
Or it could be that the bands are warn in only first gear - wich would cause damage before long..
Some shops give free estimates..
SOURCE: 2000 Hyundai Elantra gear shift stuck in Park.
check for the brake switch if this doesnt work wont release from park if this ok then i will check the shifter cable check for power and ground
SOURCE: 2001 Hyundai Santa Fe - Engine Code P1602, stuck in gear
Im having the same problem with my 02 Santa Fe. How do i go about fixing this problem? And is it costly? Please help
