Washing Machines Logo
A
Anonymous Posted on Feb 18, 2013
My water pump is leaking on my ariston avl95 washing machine
Ariston AVL95 Washing Machine
5 Related Answers
Anonymous
  • 101 Answers
  • Posted on Apr 23, 2008
SOURCE: washing machine ARISTON A1600WD NOT
The drain valve is bad, replace it. hope this information could help you.
Anonymous
  • Posted on Jul 11, 2008
SOURCE: ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Anonymous
  • 236 Answers
  • Posted on Mar 16, 2009
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Anonymous
  • 41 Answers
  • Posted on Jan 09, 2010
SOURCE: We have an Ariston A1636S Washing Machine. When
COULD BE SOMETHING IN THE DRUM UNDER THE CROME PIECE THAT THE CLOTHES GO ONE
Anonymous
  • Posted on Jan 23, 2010
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
1helpful
Whether is maked sense to repair a dishwasher Ariston LTF11M121 with a repeated wash pump bearings wear out problem.
It is very surprising that what you're describing as a wasp and I believe you're talking about a water pump having continuous failures. If you're replacing that water pump yourself perhaps that's acceptable and affordable but I think at this point I would dump it and get a 50 or $75 domestic washer from a place like Facebook marketplace or the swap sheet and be done with it
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Ariston LSE 730 T dishwasher displays an erro ao1 watt is this?
A01 means The micro-switch in the base tray has been closed for 9 seconds to signal the alarm.
Water is leaking from components or hoses in the base of the machine.
Programme will abort and the drain pump will be energised.
4helpful
Dishwasher, Ariston LI62, kept flashing on R
hi there.....this usually happens when the base of the machine is full of water.....switch the machine off ....remove the two plactic inspection panels at the bottom of the machine and dry out the base....check that all fittings and fixtures in the main cabinet are secure and not leaking..particularly the transfer tube from the wash pump to the upper spray arm..(machine needs to be pulled out of its position to check this as it is at the rear)
regards Sir Galahad
3helpful
We have the Ariston Margherita front loader washing machine and cannot get the door open
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
13helpful
2answers
Ariston AVXD 129 washing machine displayed F--05
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
