Door will not open and dvd's will not play
SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
SOURCE: DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
SOURCE: GREEN TINT TO ALL DVD'S PLAYED
Your red component cable needs replaced or your red component input in either your DVD player or TV needs replaced.
SOURCE: i have a LG ht502 home theatre , black and white only
Sir avservice, I have also posted a problem about an HT502 DVD receiver + Home Theater. The sound won't come out of the speakers but only of the Plasma tv. But was working before. And the word "PROTECTION" is appearing on the display screen of the dvd receiver. But good quality picture on the plasma tv. Please help
SOURCE: Looking for the hack to get the LG HX995TZ (home
Hello Maxraez,
1 - On the default (LG logo) screen, with no DVD playing (it does not
matter if you have DVDs in the trays) Type "Pause" then "1472". A Prom
Setting screen should come up.
2 - Press up on remote till you reach 05 Xe where X is a number (region code) eg. 1e
3 - Type "0" then hold down "5" for a few seconds then release. It
should then read as 0e. If it does then press "enter" on the remote. If
it doesn't try pressing the number "5" a little bit longer till it does.
Then press "enter".
4 - Press the "pause" button again once the above is done. That will
exit you out of the Prom screen and back to the default screen.
5 - Power off then power back up the machine. It is now region free.
A word of advice... Make sure you write down all your numbers &
letters in the Prom Screen before you change anything. That way you can
change it back to what it was in case you changed something else by
accident. However, I would caution you NOT to change any other thing.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
• Is the remote control being operated within its operation range of angle and distance?
• Are the batteries exhausted?
• Have you selected the mode(TV/DVD) functions of the remote control (TV or DVD) correctly?
