Water Heaters Logo
Debbie Freschl Posted on Feb 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an 80 gallon Rheem Hot water heater #81V80D A. In the last 5 days it stopped heating water after 6PM. I have hot water all day, but none at night. What do you suggest?
Gene Haynes
Level 3:
  • Rheem Master 5,391 Answers
  • Posted on Feb 19, 2013
Gene Haynes
Rheem Master
Level 3:
Answers
5391
Questions
0
Helped
2606428
Points
14124
1) I bet the water heater has hot water, but hot does not arrive at tap because of bad faucet cartridge or bad recirculation system check valve
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#crossover
2) When cold water arrives at tap, go check if water heater has hot water. Then do the crossover test. Then add comment and say what you discover
3) Electric water heaters can be repaired by homeowner using generic off-the-shelf parts from local hardware store.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Jan 09, 2009
SOURCE: Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Bill Johnson
  • 306 Answers
  • Posted on Sep 29, 2009
SOURCE: Rheem 50 gallon gas water heater less than one
it could also be the dip tube. this is a tube that is installed at the time the unit is made.it is a plastic tube that is on the cold intake side of the hot water heater.it may have fallen inside the unit or may not be in the unit at all check to see if there is a plastic tube this will help the heater stay hotter for a longer period of time. good luck with your project.
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Jan 05, 2010
SOURCE: My rheem water heater doesn't seem to be heating
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
Anonymous
  • 6 Answers
  • Posted on Feb 03, 2010
SOURCE: Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Peter Hampton
  • 193 Answers
  • Posted on Apr 21, 2010
SOURCE: Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Testimonial: "It is very good advice. I bought a tester to check out both upper and lowre thermostat and heating element; I've replaced the lower heating element "
I need part # for heating element 81V80D
Buy generic element from hardware store:
Copy following link to identify element and see installation tips.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
80 gallon, non-simultaneous electric heaters usually have 4500 watt elements
Avoid promotion of 'lifetime' or 'resistorized' or 'all copper' elements as a waste of your money, ... but might be beneficial by adding surge to the economy.
1helpful
Energy factor rating
Rheem 50 gallon Pro52-2 has EF .95, which makes it ordinary 240Volt 4500 watt non-simultaneous electric water heater that produces about 21 gallons hot water per hour, with 67 gallon first hour delivery.
Recommend 80 gallon per hour first hour for oversized bathtub.
http://bostonheatingsupply.com/Rheem/Rheem%20Residential%20Electric/Professional/Rheem_ResidentialElectric_Professional%20Spec%20Sheet.pdf
Maintain electric water heater and it will last indefinitely.
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Anode rod is located on top in separate port.
Anode keeps tank from rusting.
Year of Rheem water heater manufacture shows 3rd and 4th digit of serial number.
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
1helpful
3answers
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
No water pressure
Check all valves are open, cold in bottom, pushes hot out top, and if cold at tap is doing same, take aerator off tap and see what happens. Is same thing happening at all taps?
Extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
We have a Rheem PowerVent, 36,000 water heater for nine yrs now. This is the 5th time we seem to have a problem. We only get about a 5 minute hot shower and it turns cold. Is this water heater a...
Is the water heater in a basement or an area thats cold? A water heater jacket may help.
If not ,try setting the heat up a little higher on it until you have more then a 5 min hot shower.
May pay you to get a 100 gallon heater.
1helpful
3answers
Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
