The plastic fan housing broke where the metal tube goes into the plastic housing. from the parts diagram i need #20. It now says there is a new design and its 20 A. It does not have a #19 or # 20 on the order form anymore. Is this new design going to fit my older vac?
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
SOURCE: Oreck xl vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19805&thid=719784
Oreck XL vac
Posted by ddevol on Jun 29, 2008
Air flow tube is plugged. I can't get it apart to clean out. It says to press the 2 pins at the base but they don't move when I try to press them, even using pliers.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The tube going into the motor section is to push the pin and then twisted, the lower part get a dust and dirt build up and sometimes hard to remove, give it a shot of WD-40 @ the top and bottom of the fill tube and then repeat the pus in the tab and twist and it should come loose. There are also in the bigger cities the Oreck stores that you can also bring it to as well. If you have further problems or you do not have the strength to do this, bring it to a local vacuum cleaner dealer in your area and it is only a 5 or 10 minute job to remove the tube and to unclog the vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Oreck XL Leaks Dirt At Bag Entrance
do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
SOURCE: formed metal wire inside handle
this bent metal wire goes right at the surface in a grove where the two pieces of the handle go together where your fingers grip it. I think it is to discharge static electricity.
SOURCE: installing roller brush for oreck XL 21
uh, probably not sure what the issue is, but
1. unplug unit.
2. Remove the multiple screws from the bottom of the unit.
3. remove the bottom baseplate (usually black)
4. the brush roll is now visible, and the belt should be around it.
5. Pull the brush roll away from the unit, and disengage the belt.
6. Replace in the opposite order. Make sure that baseplate fits properly to insure a good seal. Also watch the bumper (rubber part that is wrapped around the unit) to make sure it is properly seated.
7. Handroll the roller brush before plugging in. Make sure it moves freely.
8. Run unit, may get a slight burning smell, but if this continues for more than a minute - turn off and inspect the unit. Brush roll requires a short burn in time, on initial build, factory accomplishes this during test procedures.
