Question about GE JRP24 Electric Double Oven
Jrp24bod1bb GE Double Oven
I want to replace my GE Double Oven, but the measurements on this oven seem smaller than what i'm finding on the internet. I was told I would need a cabinet size of at least 28" width, but my current cabinet (with the jrp24 installed) is only 25" wide. Can anybody confirm the actual size of the JRP24? And is this size not standard? thanks! Dennis
Posted by smithtx29 on
daniel hendrickson
    President:
  • GE Master
  • 1,922 Answers
You would need a minimum of 48&1/8" high,23&1/2" Deep, and 22&1/2" wide and 14" off the floor for ventilation per G.E quick specs
Posted on Feb 25, 2013
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Replacing a 30 inch wall oven -
a number of solutions for your problem a little smaller better then a little larger, iv seen depending on surrounding cabinetry, either wood fill strips, lexan(plastic) strip added as a filler. depending on what the installation guide recommends for opening , that is all that would be required what you fill if with will be a purely asthetic choice
Posted on Nov 13, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: I actually have a very
WB44X0200 BAKE UNIT 208/240V
this bake element should work I would take your old one with you and compare the way it mounts to the connections..
Posted on Aug 16, 2008
Anonymous
  • 750 Answers
SOURCE: replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Posted on Sep 25, 2008
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: installing ge profile double oven
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Posted on Jan 18, 2009
  • 6164 Answers
SOURCE: how to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Posted on Oct 29, 2010
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
What size microwave oven do I need to replace a GE jkp85?
You may have to do all the work to find one! After you take complete measurements (length, width and height) you will need to go to the appliance store with many choices to match it up!
Jan 12, 2013 | GE JKP85 Electric Double Oven
What size breaker and wire for this oven
Hello Sbilko,
I understand that you are tring to find a breaker and wire size for your GE JKP28 Double Oven. As I look up the specs on your oven I find that both ovens are rated at 30 amps. This requires you to use two thirty amp breakers one for each oven. The industry standard for Oklahoma requires that you use at least #10/2 wire for a 30 amp breaker. However, in some places it states that you can use #12/2 although I would not recommend using #12 gauge wire.
My suggestion to you is two 30 amp breakers and #10/2 gauge wire, this should be what will take care of the circuits and keep the wire form heating up.
Thank you for choosing FixYa.com
Justin
Mar 29, 2011 | GE JKP28 Electric Double Oven
How to install GE JKP35DPBB 27" Double Electric
I hope this helps.
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
I have a jrp24bod1bb but that model number doesn't seem to exist on the internet how do I find a replacement control panel
Hello- The oven control (computer/clock) is available thru applianceparts.com and repairclinic.com for about 120$. The control panel is about 250$. Make sure on-site diagnostics confirm which one before replacing. Let me know if this info helps- have more if needed.  Thanks-  Ed
Mar 17, 2010 | GE JRP24 Electric Double Oven
Older GE oven self clean mode beeping with F2???
HI, this will happen when the oven Control senses oven temperatures above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jul 24, 2009 | GE Profile JTP56 Electric Double Oven
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Nov 20, 2008 | GE JRP24 Electric Double Oven
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
I can help you!
Sep 25, 2008 | GE Ovens
Open Questions:
See all GE JRP24 Electric Double Oven Questions
GE JRP24 Electric Double Oven Logo
280 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
