Hi i'm having some troubles with my u-mix 44 soundcard. When i use it for my DAW's or for other music it has a signal and i can hear sound. However, when i want to play a game on my pc (it doesn't happen a lot but still), i can't hear sound from my speakers. Can anyone help me with this?
SOURCE: 5.1 surround not working
I uninstalled the previous audio software that the computer had. (Realtek HD audio) and turned off the onboard sound card in the BIOS settings. Then I went back and uninstalled all the new audio software and reinstalled it with all antivirus programs turned off. The main trick was to make sure that the matrix is turned off. If it is on it will play sound from all the speakers at once as if it were mono. Turning it off after changing the BIOS and uninstalling the old software and reinstalling the new allowed it to work properly. I hope this helps.
SOURCE: My PC gets stuck...
it occurs bcoz of ur ram....
if u extend ur ram capacity there may be chances to avoid those....
SOURCE: I have a Dell Dimension 9100 and Creative
Ok
Do the following, power up the PC and hit F12
Select DIAGNOSTICS - let em load and run only the sound test. This will make sure the speakers and cable are working. (make sure thewy are plugged into the right hole) then power on the system and hit F2 to enter the BOIS and make sure you disable on the on-board sound card. This is the one that is on the motherboard not the add in card.
Reboot the system and then try your speakers in the SB card and see what happens
Hope this healps you
Mark
Testimonial: "- OMG - You saved me!! This problem has been since May 26th and music is my life. Thank you so very much x"
SOURCE: emachines 180 desktop sound problems
Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
Ok now you need to call up ether the sound card application or preferably the windows volume control from the bottom toolbar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check that EVERYTHING is ok.
If there is still no sound check the control panle for any hardware issues and rectify those
SOURCE: Hi, The game, Nancy Drew: Danger
The first thing you should try, is to update both JAVA and Flash. If it uses those, that is likely the issue.
Here are the links:
http://www.java.com/en/download/inc/windows_upgrade_xpi.jsp
http://get.adobe.com/flashplayer/
Be sure to uncheck the boxes that install toolbars. Also, it wouldn't hurt to make sure that Windows is up to date. Click the Start button, click All Programs, and then click Windows Update.
Hi Daw, As you've already checked the crankshaft sensor, sounds to me as if the problem may be from the camshaft pickup sensor. If that one also proves fine you'll need to have the anti theft system re-coded. The anti theft unit cuts the injection. Regards John
