Since you tried your battery on another pc, then try a different charge power supply on yours. You may have a bad power supply adapter or your battery terminals on your pc may be dirty and need to be cleaned with rubbing alcohol and a cotton swab.
Try this link, refers to the n600c more than the 610, but that is the exact same battery so it is the right info:
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=924170&admit=109447626+1270290738660+28353475
or click HERE
Good luck!!
I have compaq Evo N610c, which would not start when i press the power
button, & when i press the power button or slide reset button the
battery led blinks umber 8 times and then green 1 times of the HDD
led.what should i do, would you please help me, thank you//
When you plug the laptop to the power adapter, you should see the indicator led lit up telling that it has good connection to the ac adaptor. It wont turn on because either there is a loose connection to the power adaptor and hasn't been charging the battery, or the power adaptor itself is bad. Check the power plug with a miltimeter, it should be around 19 Volts.
It is a known fault with the speakers - obtain a replacement set but be aware though the panel is easy to lift the plugging in of the cables into the m/board requires some dexterity.part number from hp,
241438-001
Switch cover - Plastic panel above keyboard that houses the LEDs, power switch, and Internet buttons plus speakers
