Not used it for long time, Just connected for the first time , taken only 2 pages of print,Got Alert warning of sc542,can anyone pls suggest fixes?
1. ATTACHED PRINTER TO COMPUTER AND TURN IT ON
2. OPEN PRINT PROPERTIES
3. CLICK ON SMART ORGANISER, IF U DO NOT HAVE THIS DOWNLOAD AND INSTALL FROM RICHOH WEBSITE
4. CLICK ON ABOUT
5. MOVE MOUSE ARROW KEY TO PICTURE ABOVE TEXT BOX INSIDE BLUE AREA
6. HOLD SHIFT AND CONTROL KEY AND DOUBLE CLICK RIGHT MOUSE BUTTON TO OPEN SERVICE MENU
>>>>> DO NOT PLAY WITH ANY OTHER SETTING OR YOU MAY PERMANENTLY DAMAGE UR PRINTER<<<<
7. CLICK ON RESET SC FUSE ONCE ONLY. (IT WILL BE SECOND LINE TOP LEFT SIDE)
8. FROM MAIN POWER SWITCH TURN POWER OFF AND AFTER 10 SECOND TURN IT BACK ON.
9. UR PROBLEM WILL BE SOLVED.
thank you very much. you save my money and time, thank you
thank you for such a valuable tips... thank you very much again.. [email protected]
Thank you very much for this I have solved my problem form this.
Sir . If problem as it is then what'll do
This was really helpful. Problem resolved... Saved time and money.
Navpreet singh
Excellent it working
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
SOURCE: Ricoh SP C410DN Will Only Print One Page
Hello sir; you need to set up your system from printer, go to manue ,roll down to system , roll down to auto continue,then press enter ,
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
SOURCE: Ricoh Aficio SP C411dn error SC542
It represents a fuser (hot section) failure you must enter service mode to reset. New fuser time?
Go to Smart Organizing Monitor. Now click on 'about' button.The tricky part comes now. Hold the 'Shift' and 'Ctrl' Keys simultaneously and keeping these pressed down, double click the RIGHT MOUSE BUTTON. Here comes the maintenance window! On this window, you can perform the necessary maintenance. After that click on 'apply', then on 'OK' then close the window, turn the printer off and again turn it On to apply the changes made.
Thank you very much. Pages set to zero.
Might try it on an old chip now. Tried it on an expired chip. No luck, but Print totals zeroed and error log cleared.
See how long this new chip lasts. It had only done 5 pages.
To get the apply button active after factory Default you might need to set destination, like EU to something different, then restore to what you want.
