It worked for 2 years, then it won't start up!
SOURCE: My kodak easyshare sv811 digital picture frames music not playing
Most files you download say from I tunes are "protected" files. They will not transfer. You have to convert it to an MP3 file. I found a free converter on the web that will convert your protected files to MP3 file then you can download it to your photo frame. i just bought one today and it took me ALL DAY to figure this out. What a PAIN! good luck!
SOURCE: Kodak EasyShare EX1011 Digital Picture Frame
Probably a loose cable or a problem with the circuits
SOURCE: How can I display pictures in "random" order on my digital frame?
Go back to the Home screen and go to the Settings. Select Viewing Options and activate Suffle/Random.
SOURCE: I'm trying to transfer pictures from my computer to the picture f
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
SOURCE: the Kodak easyshare S510 frame is down
I think you have no option but to have your frame repaired by kodak, you can contact their support line at 1 800 235 6325 use ext. 14
