It just blinks
SOURCE: My kodak easyshare sv811 digital picture frames music not playing
Most files you download say from I tunes are "protected" files. They will not transfer. You have to convert it to an MP3 file. I found a free converter on the web that will convert your protected files to MP3 file then you can download it to your photo frame. i just bought one today and it took me ALL DAY to figure this out. What a PAIN! good luck!
SOURCE: Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: How many pictures can the Kodak EasyShare SV811
SV811 doesn't have a large enough internal memory thats why the picture capacity depends on the inserted SD card or if you transferre pics directly from the computer to display simultanously.
The frame should display as many as on the SD card.
SOURCE: Need a Manual for Kodak EasyShare SV811
Please follow the link for the manual.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00721/PictureFrame_GSG_GLB_en.pdf
SOURCE: The EasyShare SV811 will not start up
please try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
