Question about Precor EFX 546i Elliptical Version 4
Precor Error 05, Key Depressed at Power Up
Probable Cause
1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
Precor Error Code 05
Posted on May 15, 2014
SOURCE: I have an efx 546i and when I try to use the
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Posted on Mar 19, 2010
Jan 22, 2014 | Precor EFX 546i Elliptical Version 4
Jan 17, 2014 | Precor EFX 546i Elliptical Version 4
Dec 27, 2013 | Precor EFX 546i Elliptical Version 4
Dec 23, 2013 | Precor EFX 546i Elliptical Version 4
Feb 19, 2013 | Precor EFX 546i Elliptical Version 4
Dec 09, 2012 | Precor EFX 546i Elliptical Version 4
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
Feb 06, 2010 | Precor EFX 546i Elliptical Version 4
543 people viewed this question
