Question about Pro RX65 Radar Detector
Bel gx65 both lights come on using the powercord
Both lights come on using the powercord
Need to convert from 220v to 110v. Where can I get a wiring diagram for an unidentified bench grinder?
To convert it its possible more expensive then buy an other grinder but there is some trick to connect in serial on the powercord a light bulb on a special choosen ability differs on the RPM or use a variable power resistor also in serial connection between on one of the 2 wires on the powercord.
Nov 16, 2015 | Grinders
Wont power on at all i think my cord shorted out is it repairable
see if you are getting 12 volts at the point where it plugs into the radar detector if not replace cord otherwise replace radar detector.
Aug 12, 2015 | Bel Professional Series GX65 Radar...
I have a flashing red light where the white light should apper
it might be your power cord, if the battery is empty and your powercord no longer working, the light will flash red to indicate it has not enough power to turn on. Try a different powercord for the same model, or have your current one tested at an electronics store.
Aug 30, 2014 | Dell Computers & Internet
Hardrive connected green light on powercord only blinking and not powering external hardive
Replace the power cable and data cable. If still no help, the drive is dead and needs to be replaced.
Jul 20, 2014 | Western Digital Computers & Internet
Is ther oil of any kind to be changed on the cr125 ?
The transmission (gear case) oil. I used Bel-Ray Gear Lube. Also change the fork oil to Bel-Ray or similar. Big Improvement!
Apr 10, 2010 | 2002 Honda CR 125 R
R 64 chevy bel air 4 door turn signal
Check the connectors on the head lights . check the dimmer switch on the floor, check the turn signal bulb sockets and make sure that they are well grounded.
Oct 02, 2009 | Chevrolet Impala Cars & Trucks
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
What kind of crankcase oil does it take?
Bel Ray Gear saver for two strokes is good stuff. Available at any bike dealer. You can also use regular motor oil (10-40w) but I've had great luck with the Bel ray. It's synthetic and made for that application.
Jul 11, 2009 | 2003 Suzuki RM 250
Which powercord to use?
In the bottom of the laptop you can find the input required, make sure the voltage matches the requirement and the connection is the right way.
from what you said I can't tell if its too stong, can you adjust the voltage? look in the bottom it is documented there on a label.
Jan 16, 2009 | Acer Aspire 1640Z Notebook
Does the bel 980 need to be upgraded ??
BEL no longer offer upgrade or repair for the BEL 980 detector
May 27, 2008 | BEL 980 Radar Detector
Pro RX65 Radar Detector Logo
42 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Perry Mellott
Perry Mellott
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
