Question about Hasbro Star Wars R2 D2 Interactive Astromech Droid
R2 won't move forward on command
When we tell r2 move forward, he responds with noises, but then doesn't move
Posted by Jennifer Smith on
Clint Hall
    New Friend:
Have you checked to make sure his wheels are unlocked? Page 4 of the manual shows you where it is. http://www.hasbro.com/common/instruct/SW_R2-D2_Interactive_Droid.pdf
Posted on Nov 08, 2013
Tip
Which BGP show command for internal prefix count?
Question:
I have two WS-C3560V2-48TS-S routers (R1 and R2); R1 has the full BGP table and some local connections to. They are all being advertise to it's iBGP neighour R2. I can't find a command that I can run on R2 that will show the number of prefixes learnt from R1 that are internal to the local AS only. It just says 425~k which is all the Internet routes and the local ones.
What command can I use for this?
Answer:
the local AS originated networks has AS path attribute empty.
So you could define an ip as-path acl matching an empty string
ip as-path access-list 1 permit ^$
then you can invoke the as-path access-list as a filter action on show ip bgp on R2
show ip bgp filter-list 1
see
BGP command reference
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/command/bgp-s1.html#GUID-2618748E-42ED-495A-875C-D398A02D79F9
At this point it is enough to count the lines in show ip bgp filter-list 1 output to count the routes that are originated in the local AS at R1 WS-C3560X-24P-L Price and received on R2 and installed on R2.
Original comes from http://switch.blogcindario.com/
on Sep 03, 2013 | Computers & Internet
Crosley washer won't agitate
Hello Carroll Mcknight - Is the washer making a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the unit may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to assist with the repairs and to move forward accurately.
Jan 22, 2013 | Washing Machines
Whirlpool washer problem spinning
If it makes noise but moves, it's your motor - it it doesn't move at all, it's the belt. Noise and won't move, get a new washer. Check the BELT first - that usually is the problem.
Jul 22, 2012 | Washing Machines
My rebuilt transmission won't go forward?
i would be checking the shifter cable adjustment first see how that goes goodluck
Sep 18, 2017 | 1992 Ford F250
Tesco ej09 sewing machine - handwheel wont turn
I actually had the same problem, it turned out that after threading a bobbin I'd forgot to slide the bobbin holder back into place (just push it to the left) Hope this helps
Apr 14, 2012 | Sewing Machines
Intimidator light wont come on
I have 6 of these in my lighting rig, and the most common problem has been a bad bulb socket. If your bulbs end up with corroded or blackened terminals, you should replace the socket. The black/corroded stuff can cause the connection to become intermittent, sometimes so badly it entirely doesn't work.
The other common problem I've seen involves a resistor on the circuit board that powers the light bulb. I believe it's R2 - regardless it's the only big one. It's value is .5 ohms at 3 watts. Be sure to use a flameproof resistor when replacing it, and most likely your fixture will light up again.
Dec 20, 2011 | Chauvet Intimidator 1.0 Dmx-600 512...
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
Hasbro Star Wars R2 D2 Interactive Astromech Droid Logo
420 people viewed this question
Top Hasbro Toys Experts
Marvin
Marvin
doconnell13
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
