Question about Garden
What is the standard diameter of a garden hose in England?
Posted by igor doppler on
rodney ashkel
    New Friend:
    Problem Solver:
  • 13 Answers
Everywhere outside the US, the standard diameter for a garden hose is 3/4 of an inch, or 19.05 mm
Posted on Feb 17, 2013
How do I connect to the bbq gas point on the van as it is larger than the hose diameter?
go to gas fitting supply shops (BBQ) retailers and get the correct hose
Apr 23, 2018 | Garden
Standard garden hose does not work since Haier drain hose connection is metric, not standard. Any solutions?
Never heard of a metric garden hose connection. Was this unit purchased in the US or overseas?
Check box or bag with manual. There may be an adapter in there.
Sep 13, 2017 | Haier Dehumidifiers
Would anyone know if i can use a 3/4 dryer hose?
A dryer hose is typically four inches in diameter. They are flexible and they have an accordion design, so they stretch out.
The 3/4" drain hose can be a plastic hose or rubber hose. Depending on how long the drain hose needs to be, an inexpensive 3/4 " garden hose may be the most economical. Just make sure the is 3/4" in diameter. If you need a short length of hose, a piece of 3/4" plastic hose may be the best bet.
The dryer hose and plastic drain hose can be purchased at Lowes or Home Depot.
Jun 05, 2014 | Danby Heating & Cooling
A garden hose with an internal diameter of 1.9 is connected to a (statoinary) lawn sprinkler that consists merely of an inclosure with 24 holes each 0.13 cm in diameter. If water in a hose has a speed of...
let us consider the velocity of sprinkler is V2 rate of mass flow will same at a time so incoming mass flow = outgoing mass flow so from the principle of continuity A1 V1 = A2V2 since sprinkler is is N = 24 then A1V1 = NA2V2pi* (D1 / 2)^2 *V1= pi*(D2/2)^2*V2V2 = D1^2*V1 / ND^2V2 = (1.9x10^-2)^2 *0.91 / 24*(0.13x10^-2)^2V2 = 8.1 m/s^2
May 14, 2014 | Garden
I need filter cartridges for Intex Spa
sometimes these can be hosed off with a garden hose and reused a couple of times..
Mar 06, 2014 | Intex Pool & Spa
What is the standard diameter of a garden hose in the US?
In the United States, the standard diameter from the outside of the thread is 1 and 1/16 of an inch, or 27 mm.
Feb 17, 2013 | Garden
I need to replace a hose on a Danby portable airconditioner model # DPAC120068
The first place to start is with the manufacturer, Danby 800-496-6049. Or take a section of the hose with you and go to your nearest home center and purchase a similar hose (same diameter) and use all the existing fittings that you have, to remount it with the new hose. There are several types available that will work well for this type of application and probably last longer than the original hose did.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
The hose on my accuspray turbine Hvlp system is collapsing once it gets hot. Do hoses wear out like this, and can I replace re hose with a standard garden hose, or do I need to buy an accuspray hose?...
The hose supplied by Accuspray does soften as it warms up but should not be collapsing. Most hvlp turbine system manufacturers supply a hose with a helix reinforced hose that will not collapse.
The majority of hoses for hvlp systems are 3/4" inside diameter hose like the Accuspray hose and will work with your system.
The fittings will work with any 3/4" garden hose. Problem with using garden hose is that the cheap ones will collapse and kink and the quality ones will be heavy.
May 31, 2011 | Garden
Hi! i remove the lint filter to clean it and i notice that there is more lint stock in the slot. is there a way to reach in or from the back?
Yes, this is a problem for our Nexxt dryer as well. I took an old garden hose, cut about three feet off it, then took a cap from spray paint can, cut a hole in it the diameter of garden hose. Put the hose in the cap. The spray paint cap fits nicely on my shop vac. Took the shop vac in the laundry room and attached the spray cap with the garden hose inserted and vacuumed the lint from the slot using the end of the garden hose. Worked pretty well. If you don't have a shop vac you may be able to stick a flexible hose in the end of you home vac and hold it with your hand to seal it. That should be able to remove most of the lint. Good luck.
Dec 12, 2010 | Bosch Nexxt 500 Dryer
94 caprice classic rear spider gears shot 12 or 16 possi what other rear ends are compatible for this 5.7 liter
. Axle Code >>>>>>>>>>>Standard
2YN Gear Ratio >>>>2.56<<<<< Ring Gear Diameter 8.5 Standard 2GA Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GB Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GH Gear Ratio 2.73 Ring Gear Diameter 8.5 Standard 2LW Gear Ratio 3.08 Ring Gear Diameter 8.5 Standard 2LR Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LY Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LT Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 6YF Gear Ratio 3.23 Ring Gear Diameter 8.5
Axle Code>>>>>>>>> Limited Slip
2LQ Gear Ratio >>>>>>>>2.93<<<<<<<<<<< Ring Gear Diameter 8.5 Limited Slip 2YG Gear Ratio 2.93 Ring Gear Diameter 8.5 Limited Slip 2LX Gear Ratio 3.08 Ring Gear Diameter 8.5 Limited Slip 2ND Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LZ Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LS Gear Ratio 3.23 Ring Gear Diameter 8.5
Nov 28, 2010 | 1994 Chevrolet Caprice Classic
Garden Logo
306 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
