Televison & Video Logo
Susan Knutson Posted on Jan 22, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why GE TV plays color DVD/VCR tapes in black and white
Attaching a Sony Model #SLV-D380P DVD/VCR combo player to a GE Color TV Model 25PM4836L and color DVDs and VCR tapes play in black and white on the TV. Same DVDs and VCR tapes play in color if the Sony Combo player is attached to another color TV. Can color DVDs play in color on this model of TV.
Vinho Xie
Level 3:
Genius:
  • GE Master 1,419 Answers
  • Posted on Jan 04, 2022
Vinho Xie
GE Master
Level 3:
Genius:
Answers
1419
Questions
0
Helped
416430
Points
4431
Possible cause: incorrect cabling.
If the image connected to the DVD player turns black and white, then check if the connection to the TV is correct. If only three wires are connected, then it is connected to the normal AV interface. Now there are video components behind the digital HD TV. Interface, connecting component interface requires five lines, three-component videos and two audio lines to watch normally. If the image suddenly turns black and white during the viewing process, it may be faulty.
Source: Why is My DVD Playing in Black and White
Gary Dumers
Level 2:
Habit-Forming:
New Friend:
  • Expert 131 Answers
  • Posted on Jan 22, 2018
Gary Dumers
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
131
Questions
Helped
48893
Points
371
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
  • Gary Dumers
    Gary Dumers Jan 22, 2018
5 Related Answers
jason
  • 905 Answers
  • Posted on Nov 07, 2008
SOURCE: my tv shows are taping in black and white
if you have the dvd's s-video plugged in and also something plugged into the yellow video input this will happen , does the piture on the tv show black and white?
otherwise the vcr head is dirty and needs to be cleaned
please rate a fixya and I'll be happy to even assist you further
electech
Anonymous
  • 1179 Answers
  • Posted on Feb 08, 2009
SOURCE: DVDs on my Sony SLV-D350P DVD/VHS player play in black and white
First try a good quality dvd cleaner. If that does not cure the problem then the video cable may have went bad. I had a system that the cables were never touched & after a few years it needed replaced in order to get my picture back. Hope this helps & please take a moment to rate my answer. Thanks.
Jamie Andrew Knights
  • 244 Answers
  • Posted on Mar 24, 2009
SOURCE: Dvd player is only in black and white...no color
Hi, make sure your av chan say`s av2 and not av2s as this will give b/w playback Jamie
Anonymous
  • 10594 Answers
  • Posted on Nov 15, 2009
SOURCE: my sony dvd/vcr combo will play cds but not dvds
Please clean laser lens with good quality cotton bud gently and check dvd disc playback, if still does not play, replace optical lens block.
Let me know model number of your Sony DVD-VCR combo to provide you optical laser block part number info.
Thanks.
Anonymous
  • 309 Answers
  • Posted on Nov 20, 2009
SOURCE: DVD freezes when playing on a Sony SLV D300P DVD/VCR
That particular unit is very sensitive to scratched or dirty disks. Remove the disk and make sure there are no finger prints, peanut butter & jelly, or popcorn butter stains on the back side. If there is, gently wash the disk under warm water with a DROP of mild dish detergent, being careful not to scratch the surface. Rinse the disk well and dry with a soft, lint free cloth (like an old cotton t-shirt) again being careful to avoid scratching the disk. Replace the disk and play.
If the disk is scratched, there is little hope of fixing the scratch so the unit can read it.....
Can Sony D380P play blue ray disc.?
If your player is the Sony SLV-D380P, the unit does not play Blu-ray discs. It is only a DVD player and VCR. It can play some CDs. The discs must be finalized for homemade video DVDs and audio CDs. You can find the specifications and manuals here: https://esupport.sony.com/US/p/model-home.pl?mdl=SLVD380P&template_id=1®ion_id=1&tab=manuals#/manualsTab .
I hope this helps.
Does a Sony D380P play. blue ray. Disc..?
No. DVD cannot play Blue Ray disc.
You need a BluRay player or PS3/4.
The technology and the media capacities are very different.
I own a sony dvd player /vcr combo model no. slv-d380p it plays dvds in black and white instead of color
The problem is in the color processing ic, far cheaper to replace the player than have it repaired.
3answers
Black and white dvd playback
because on line out video mode are in NTSC and not in PAL how must be to play in color mode
Which components is responsible for the auto tracking in the sony vcr, model slv d380p
Auto tracking, or 'digital tracking' as it is sometimes known, is generally governed by the CTL (the linear control track head), located toward the right-hand side of the main head cylinder drum, along with a combination of the guide posts/rollers, the capstan speed as the tape travels in the deck, and of course the drum balance since this rotates the fastest. Usually this is pre-aligned to factory standard, but as parts wear down, the alignment changes - hence your 'tracking query'.
Presuming you have a video picture from your tapes on the TV screen, you can bet the tracking is controlled electro-mechanically (as above). One of the first parts on the mech to wear out is the rubber pinch roller - when it becomes glazed or shiny, tapes can be chewed and/or the 'control track' drifts during playback - more so than when recording.
Nevertheless, it is usually a simple workshop repair involving inexpensive part replacement/alignment on the mechanism including a new pinch roller and cleaning of the entire tape path. The only 'cost' would be labour on top of the parts. The option here is that you can submit your unit to a workshop/service centre for a quote on repair/parts costs first, then decide if you want the tracking fixed - up to you. I hope you have no other really serious issue with this combo unit - SONY is a premium brand - trusted and reliable. I assume the DVD section works fine.
Remember; bad tracking is not always a mechnical mis-alignment - it can also be the quality/age/condition of the tapes a person uses as well, even if that person doesn't 'thrash' tapes on a daily basis. From memory, the SLV-D380P is one of SONY's better DVD/VCR combos.
1helpful
My sony dvd vhs player is displaying only black and white split screen how do I fix this? nothing is wrong with the vhs
You have the Chanel Finder activated, usually a small switch on back, or somewhere it is used to give a "Pilot Signal" so the TV set can be tuned.to that signal, after you find it, you turn it OFF on the VCR. Or maybe the remote, check in your manual.
I have 3 vcr's and none of them will play my tapes. (just Static) I have sound and I can play DVD's.
Perhaps some of the belts that help your vcr run are stretched out. These belts can be replaced through your manufacturer or you can get them from your local Radio Shack.
2helpful
2answers
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
