My Kenmore Elite water softner won't allow me to adjust salt level anymore. I filled up to level 7, then tried to add salt level nothing happen. I tried to push the minus sign to see if it works, nothing. What should i do? Now i have flashing light indicates low salt level eventhough the tank is full.
According to BBQ's Galore, no you can't. This is due to it's overall design as a built-in grill head. On the surface, the grill heads look similar, but there are some significant design differences that would affect it operation..
remount the scope using millett angle lock rings that allow you to adjust for windage. bring the scope as close to hitting bulls eye as possible then use the scopes adjustments for the fine tuning. before remounting you will want to recenter the reticule.
Your support plate under tub above gearcase was knocked out of place, lean washer back and try to adjust plate back in place were it is sitting back on the glides. This is not an easy task bu it can be done,sometimes it is best to call a repairman to do the repair so he can check if there is any more damage.
is the eprom settings set correctly for the input beeing used,you must enter the service mode to inspect and adjust the settings,call your local dealer for assistance.
