Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Kenmore coldspot 106.56683501
Icemaker not working
5 Related Answers
Anonymous
  • 35 Answers
SOURCE: Kenmore Coldspot 106 54689300
DID YOUHOLD THE DISPENSER FOR A LONG TIME AND PURGE AIR ??? ARRE YOU GETTING ICE???
Posted on Jun 18, 2009
Anonymous
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
Anonymous
  • 1891 Answers
SOURCE: My icemaker is turned on and hooked up properly
your mod is probably type with wlect eye , if ice bucket is on door . this is the type you have , and no lever is on icemaker . the problem is with the eye .. replace the eye kit . this is a very common problem . new kit is revised / and works good .. mm feed back pls .
Posted on Dec 17, 2009
Testimonial: "Sweet man, thats it....Love you brother..."
Anonymous
  • 86 Answers
SOURCE: I have a kenmore coldspot
Hello there:
That must be your water solenoid valve this is the item to check it out first.
at your service Dickson
Posted on Nov 04, 2010
Anonymous
SOURCE: I have a leak inside my Kenmore Coldspot Model #
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Posted on Jan 29, 2011
I have a Kenmore 55602400 Coldspot and the icemaker has stopped making ice. What do I need to do to fix it?
The model number you listed is for an air conditioner. Please check inside the refrigerator for the model number?
I have a Kenmore Model 106-55602400 Coldspot and the icemaker stopped working. What do I do?
The control module has failed on the ice maker. You can replace the control module alone, but I would replace the ice maker completely.
Here is a link for the control module.
Here is a link for the new ice maker.
Kenmore coldspot 106.55609400 icemaker not working Problems
Follow this link for the complete service manual for the ice maker. You will need to create a forum account but after you do you will be able to download the manual.
2answers
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
I have a kenmore coldspot refrigerator and the icemaker water keeps running and flooded my home, is it the icemaker or a valve?
Hello there:
2helpful
My icemaker is turned on and hooked up properly but it doesn't work there is no metal lever inside the icemaker that needs to be lifted up, Kenmore Coldspot model # 106.56534400
2answers
Kenmore Coldspot #106.9750610. Icemaker does not
restricted water flow or pressure from house water where your taped into. your shut off or Tap a line may be cloged or if you have a water filter its cloged. It could also be a bad water valve in rear of refrig. start at the sourse of water and work back to frig. A rare thing could be that the timing gear on the ice maker is burnt and not trigering valve long enough to fill icemaker
Kenmore 52552100 refrigerator not working
Hello.... do you still have the parts??
I can use Part 921526 PC Board kit, emitter & reciever icemaker - $30.
You can email me at [email protected]
Thanks,
Paul
2answers
Kenmore coldspot ice maker quit
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
2answers
Top Kenmore Refrigerators Experts
vince
Dennis
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
