Premendo fn con f6 f7 non funziona
SOURCE: how can i adjust the brightness of my tecra m1?
The brightness is automatically controlled by a "Brightness Sensor" However, you can compensate the brightness by using the Toshiba Brightness Sensor Control. In order to use this utility, you must set the Brightness Sensor in Toshiba Power Saver to "ON"
SOURCE: use FN F7 to increase brightness and FN F6 to
If you have re installed the OS, you may be missing your function button drivers.
You can alter this thru display settings and power options (control panel)
Testimonial: "thanks! "
SOURCE: i cannot adjust brightness in
hello
in the lower right side of your screen you can see the battery sign cick on it and adjust the brightness.
thank you
