Question about Kitchenaid 5 Quart Glass Bowl Artisan Mixer - Sugar Pearl Silver
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
Posted by Ian Goddard on
MendingShed.com
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Posted on Apr 16, 2013
Leaking oil in the point of the mixer
You can try running the mixer at high speed for a few minutes to try to blend the grease in the gearcase. If this does not work, then cleaning out the old grease and repacking with new is the solution.
Assuming you have a 4.5 quart tilt head, a 5 quart lift bowl (not the professional series), or an Artisan, the Service Manual you need is at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jan 02, 2015 | Food Mixers
Model 4ksm900b
Google Kitchen Aid in your home country.
Jul 30, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Why kitchen aid mixer wont turn on
Any number of reasons such as:
Bad electric cord
Bad brush or brushes
Bad armature or stator
Control plate broken
You need the Service Manual:
While this manual does not cover the Artisan specifically, the procedures do apply.
Jun 04, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Where would I find a bowl lift replacement mechanism for a kitchenaid 5 qt mixer model K5SSWW.I have a kitchenaid 5 qt mixer model K5SSWW. I need a bowl lift mechanism replacement part but can't find this...
The model number seems to be valid-but given the age of the unit few parts are readily available. You might want to try eBay or a used appliance store (or even Goodwill) to find a donor machine.
May 02, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Beater is hitting bowl
You can find the User's Manual (which shows how to adjust beater-bowl clearance) for your model at:
https://www.kitchenaid.com/customer-service/manuals/
Apr 22, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchenaid bowl lift mixer bowl support
David, that is a 6 quart mixer but uses the new 7&8 Quart mixer parts, KitchenAid has been covering those with a really long warranty, I want to say 2-5 years, and none of the service centers have seen them come in yet. That is not a problem on the 5 or 6 quart older style bowl lifts that we have ever came across, the best thing to do would be to contact kitchenAid directly. Their number is 800-541-6390.
Mar 17, 2014 | Food Mixers
Is a kitchen aid model # KSM5PSAC the same as KSM150SP?
The KSM5 and the KSM150 are different mixers. They are both 5 quart mixers and use the same gearing and motor. However the bowl design is different. The KSM5 is a 5 quart bowl lift, which means the bowl locks into the arms of the mixer and raises towards the head of the mixer, where the ksm150 mixer is a artisan mixer, which is also a 5quart mixer, but the head of the mixer tilts back and the bowl twists into the base ring to lock into place. These two mixers will take different bowls and beaters.
Thank you,
Colleen
Customer Service
MendingShed.com
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Wher can i find a manule for a 5 quart artisan standmixer to print
You should be able to find a manual here:
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KA_EN_CA
Note that your model number seems to be incomplete; I found 63 manuals for this model number; there should be 3 more characters in the model number.
Feb 06, 2011 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Sep 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchenaid 5 Quart Glass Bowl Artisan Mixer - Sugar Pearl Silver Logo
139 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
