SOURCE: setting 3300 to basic cb oper.
On the 3300hp use band switch at position A band switch to hi
SOURCE: Need to know the normal use settings for the
turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
SOURCE: can anyone explain the band knob and the pa/fm/am
p.a. stands for public address,you need a pa horn for this. F.m. is for frequency modulation alot of ten meter radios offer this now it's mostly line of site communication if you have somebody else with fm though it sounds alot better. A.m. is amplitude modulation it's the standard way cb's have communicated since the beginning.I hope this helps.Good luck. Dan
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
SOURCE: just installed a connex cx 3300hp not sure of
it should be am selector switch on d/a and hi band
