Logitech 9311570403 Mouse Logo
Question about Logitech 9311570403 Mouse
How to change batteries in HP X4000 wireless mouse
Posted by srmcameron on
1helpful
How do i change the batteries in my hp aox35aa mouse
the real name is x4000 mouse , and Product # A0X35AA#ABA (note fully stated !)
the manual at HP is under x4000 mouse
https://support.hp.com/us-en/product/hp-x4000-wireless-mouse-with-laser-sensor/5164318/manuals
all HP gives you is this lame photo.
the best batteries are many ,cheap dry cells will fail soon.
30-month battery life (is based not on cheap batteries)
but top brand alkaline battery, not old or old stock or dry cells.
the best of all is.
nothing beats Lithim
https://www.walmart.com/ip/Energizer-EVEL91BP2-Ultimate-Lithium-AA-Batteries-2-Pack-Gold/14928270
Mouse wirless computer
the plug is a radio that talks to the mouse. it mus be there when you want to use mouse. if not using mouse, it can be removed. look for storage somewhere on mouse
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
1helpful
2answers
My wireless mouse has quit working. I'm guessing I need a new battery. However, I can't figure out how to even find the battery, let alone change it! How do I do that????
Cutting down on the number of wires that must be tolerated in a work station adds to maneuverability and ease of location. For all their convenience, though, wireless accessories bring with them a number of issues not present in their wired counterparts, most significantly battery change.
Instructions
    • 1 Turn off the mouse.
    • 2 Remove the top of the top of the battery compartment. The button that releases it is located toward the rear of the mouse.
    • 3 Remove the old battery and place the new one in its place. Replace the cover and turn the mouse back on.
Read more: How to Replace the Batteries in an HP Wireless Mouse ' eHow.com http://www.ehow.com/how_6947071_replace-batteries-hp-wireless-mouse.html#ixzz1LpG7oNYf
Mouse won't work after battery change
hi, try to perform the steps in the article below from HP.. http://tinyurl.com/y8ek43e and also try to perform a diagnostic test on mouse. if its a HP computer to do so.. go to Start -- All Programs -- PC Help and Tools -- Diagnostic Tool..
once the tool is open go to Communication.. and run a test on mouse.. if ur unable to use it there.. then if ur system is under warranty.. call HP and get the mouse replaced..
let me know if this was useful to u regards, guru
4helpful
4answers
Changing the batteries in a hp optical wireless mouse
From pictures, it looks like the top part of that mouse slide down.
Try holding it with the buttons facing toward you, and pushing with your thumbs on the top silver piece of the mouse away from you.
3helpful
2answers
Wireless mouse won't work on hp multimedia cordless keyboard and mouse
Try changing the batteries in the mouse and then press the little sync button of both the mouse and the wireless receiver.
Top Logitech Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
