Well the C0F35 is because there is no toner in the image unit so replace the image unit. just buy a whole new unit. as for the c0070 try this
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Yes...Duct tape works wonders. Most of these printer cartridge have built in chips that match to the printers they were designed for. This is the manufactures way of saying "Hey, we practically gave away our printers, so now you have to pay outrageous prices for the ink"!!! Place the tape on the light and enjoy the savings ;-)
It sounds like you have a bad toner cartridge. There is a chip on the rear end of the toner that is sometimes defective. It doesnt happen often, but it happens. blog.equipmybiz.com
All of the manufacturers do the same thing to get people to buy their toners, if any toner is empty you don't get to print even black. Sometimes empty toner can scratch a drum so that's the excuse they use for making them that way.
P27 Toner density sensor unplugged or toner density sensor problem. Conduct the condition of the sensor of the toner and presence of the toner in block of the manifestation, as well as presence of the perfected toner, clean the container with perfected by toner in block of the drum. Thank you.
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
