Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
My D-LINK DIR-616 300Mbps Wireless Router is setup with different language and want to setup it with english language
mendee
    New Friend:
Hello
How do english upgurade DIR616 wireless router????
Posted on Dec 13, 2013
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Dlink DIR-300 wireless G router; browser freezes
when i login on it says pending so what do i do and the routersay that the net is hooked uo right
Posted on Dec 24, 2008
Anonymous
  • 18 Answers
SOURCE: d link router dir 300 setup cd will not load on to
You do not need to install anyhting to your computer Hook the router up and connect it to your computer and open a web browser and type in 192.168.0.1 for username: admin and password is blank. This is going to let you modify the router settings.
Hope this helps let me know if you need more info once you get to this point.
Posted on May 03, 2009
Anonymous
  • 135 Answers
SOURCE: DIR-655 Connection Support
Don't worry about it, The router is backward compatible to B,G and N only. the Router that your is wireless extreme N. Some of the A, D is not been supported by the router that means that we are on a new generation, there some older router can support the A,D.
Posted on Jun 27, 2009
govinda123
Prashant M
  • 2277 Answers
SOURCE: lost my d-link dir-655 quick router setup
Are you trying to set up the router?
you don't require the CD.
You can change the settings of the router manually also.
Click Here for more info about the router set up
Posted on Oct 13, 2009
Anonymous
SOURCE: Hi I cant configure my router D-link DIR-300
This definitely worked for me. To find out your computer's MAC address, just go to start, then click run, then type 'CMD'. When prompted, type 'ipconfig/all'. Find your ethernet adapter local area network connection, and underneath you will find a lablel titled Physical Address. This is your MAC address and should consist of 6 pairs of number/letter combinations. Then connect your computer to the modem, eithe wirelessly or directly and point your browser to 192.168.0.1. Under Setup click Internet Setup and then click Manual Internet Connection Setup. Under Internet Connection Type, select Dynamic IP (DHCP), then under MAC address, type in the MAC address of your computer. Click Save Settings and Presto! It worked for me.
Posted on Nov 26, 2009
I want change language german into english language
simply go to maintenance select second option on the router then select last option (lear ) then ok then save.now change language with english
Jan 26, 2016 | D-Link DIR-615 Wireless Router
How to change English to Chinese when we install Dir 615 in computer?
HI,
you just open the setting and threre is setting of launguage where you can change the language but thn also if you cant able to do , then reinstall the (dir615) in there also you find the launguage option
Jul 03, 2015 | D-Link DIR-615 Wireless Router
Change language chinese to english
Download English language firmware from D-Link.
Jan 31, 2014 | D-Link DIR-300 Wireless Router
Computer says that the pin number is incorrect, please use no. on modem. modem nuber keeps coming up incorrect
You should refer to your wireless router setup manual for pin number....
you can also prefer this link to search modem pin no-http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-615-wireless-n-300-router
Sep 03, 2012 | D-Link DIR-615 Wireless Router
The setup language is in chinese , how can i change it to english
Click the third tab in the horizontal, from left to right, by DIR-616 then click the third option in the vertical, under DIR-616. Now, click the button on the bottom of the page. That should clear the language pack and make the interface be displayed in english. I hope I made myself clear, I spent almost an hour trying to figure out what to do to display this interface in english, google translator helped me a lot. Good luck.
Feb 18, 2011 | D-Link DIR-632 8-Port Wireless-N Router...
How to remove a router security key from a DIR-655 D-link router?
Please follow the below steps to remove the security key from your wireless router DIR-655.
1. launch "Wireless Security Setup wizard". by clicking on setup.
2. Click "Next" , You will get a screen giving you an option to select the security level.
3. There you can select "None - No Security". & click on "Next & then click on "Save".
This would remove your security key from your wireless router.
Regards
Oct 11, 2010 | D-Link DIR-655 Wireless Router
D-link Router DIR-625 resets itself
You need to open the router's setup page (admin page) http://192.168.0.1 to enable the wireless security
Feb 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
How to put a password on dlink dir-300 wireless network
We Consider D-link Router is the Best Home Wireless Routers. Range, Connectivity, And Durability Is Great For Home Users With D-link Router
For Troubleshoot D-link Router Problems. I Explain How to Reset And Install D-link router.
I used to visit this website because of this web page content genuine information.So kindly visit on this link
https://fixingblog.com/reset-re-configure-d-link-wireless-router
Jan 17, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Computers & Internet Logo
229 people viewed this question
Top D-Link Computers & Internet Experts
Mike
RockTheHood
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
