Nikon FE 35mm SLR Camera Logo
Question about Nikon FE 35mm SLR Camera
Nikon fe how do i open the back
When was my nikon fe made?
Nikon produced the FE from 1978 to 1983.
If you're asking when a particular FE was made, you'll have to provide the serial number.
I accidentally forced the wind crank pin of my nikon FE to jam
need grease , lubricated and clean that it . I do that job very cheap
5helpful
How to open fim back door ?
While pushing the lock around the rewind knob counterclockwise with a finger, pull up on the film rewind knob until it clicks. Then pull up a little further until the back pops open.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Accurate shooter speeds but only couple of picture after develop
I HATE TO SAY THIS BUT I BELIEVE THAT YOU HAVE BEEN SOLD A DAMAGED CAMERA. THIS HAPPENS MANY TIMES ON EBAY WHEN THE DEAL SOUNDS TO GOOD TO PASS UP. FOR ONE THING YOU HAVE A NIKON FE CAMERA, BUT THEN YOU HAVE TWO DIFFERENT MAKE LENSES, BOTH ECONOMY GRADE LENSES, NOT NIKON STANDARD QUALITY. THE PROBLEMS YOU ARE HAVING ARE MOST LIKELY CAUSED FROM A CAMERA THAT HAS BEEN DROPPED. I AM INCLOSING TO HOTLINKS OF NIKON DEALERS THAT DO REPAIR WORK AND GIVE FREE ESTIMATES. YOUR BEST BET IS TO HAVE THIS CAMERA SERVICED BY A NIKON REPAIR SHOP IF YOU PLAN ON KEEPING THE CAMERA. IF YOU JUST BOUGHT IT FROM EBAY, I WOULD FILE A PROTEST STATING THE CAMERA IS BROKEN AND DOESN'T WORK AND DEMAND YOUR MONEY BACK! THEY WILL USUALLY BACK THIS TYPE OF CLAIM. GOOD LUCK! SORRY FOR YOUR MISFORTUNE.
www.percisioncamera.com/nikon-camera-repair.html
www.nikonusa.com/Service-And-Support/Nikon-Service-Information.page
if you need more help reply to: arclight1217
Shutter won't open and film won't advance
You might have a dead battery. Check that.
Philip
2answers
Nikon FE- Winder return position
YES, THE PROBABLE CAUSE IS THAT AFTER 25 YEARS OF USE YOUR POOR NIKON PROBABLY JUST NEEDS A GOOD CLEANING! I DON'T THINK IT IS ANYTHING A GOOD CLEANING CAN'T CURE. I HAVE INCLUDED A COUPLE OF SHOPS THAT REPAIR NIKONS AND GIVE FREE ESTIMATES. WHILE I DON'T ENDORSE ANY REPAIR SHOP PERSONNALLY, I PASS THESE ALONG FOR YOUR INFORMATION. I HOPE THIS HELPS. I REALLY BELIEVE THIS WILL TAKE CARE OF YOUR PROBLEMS. ALSO, BY THE WAY, I ALSO HAVE A NIKON FE AND IT'S A GREAT CAMERA. ENJOY!
www.keh.com
www.camerarepair.com/camera/repairs/264-NIKON-FE
THESE ARE HOTLINKS AND WILL TAKE YOU TO THE PAGE.
16helpful
2answers
CAN WORKOUT HOW TO OPEN NIKON FE CAMERA
Sept 19th, 2008
On the bottom of the Nikon FE, there is a silver button to push in, and this releases a lock for the film.
Then on the left side, on the top, there is a white arrow and a silver lever tucked in. Wind your film, this it's all the way back in the canister. Then the black lever by the speed film (ASO) numbers, pull that back toward you. This will release the black 3/4" knob upward, and by gently pulling this upward, your door will release and the film canister will be allowed to come out. Just besure to wind your film back in the cansiter, before you open the door, or your photos will be over exposed. Best to do this in a darker area or shaddowed area, just for protection.
Good Luck. I've had mine since the mid 1970's and love it for double exposures and the special filters I have for it. The Hot Shoe for the flash attachment, just burned out on me a couple of days ago.
Shutter remains open
The problem could lie in the meter/speed dial unit or in the shutter itself. New parts are no longer available for that model. You may be able to find a good one on one of the auction sites or even Craigslist. A good used one would be less than a repair even if parts were on hand.
Nikon FE
TRy firing the camera in the M90 setting. If it fires properly, use the battery test switch. If the battery LED doesn't light up, replace the batteries (2 MS76 type). The FE requires healthy batteries to operate the shutter. If the meter is calling for a slow shutter speed (low light or lens cap still on?). If the batteries are good, but the shutter still won't fire normally in sufficient light, looks like you're in for a repair shop visit.
Top Nikon Photography Experts
Steven Wander
Steven Wander
Marvin
Marvin
Steve
Are you a Nikon Photography Expert? Answer questions, earn points and help others
