Ihave been able to connect usb hard drives to my Acer. unfortunately the unit will not delete the links created to the movies that were on the drive - even though I unmounted the drive. So there are all these links inside the multimedia player that does not work. Recently I removed then replaced the SD card and now have two links to the movies on it, on link from before and a new one since putting the SD card back in. How do I get rid of these dead links?
SOURCE: Blue Ray Software
Just do recovery your notebook. try to run the acer Arcade without upgrade it. I also have some problem when I upgrade/ update my Acer Arcade to latest Version. I'm using Aspire 6920G.
SOURCE: SD CARD is not working
I reccomend that if you can find a driver for your sd card slot, install it so that your slot could be compatible with all sd cards including HCSD cards.
SOURCE: Distorted / skipping sounds from Acer laptop
Go to the sound icon which is at the right hand bottom corner on your task bar, explore properties cheack wheather voice supression is any thing else than 0.As well as check for enviroment.
SOURCE: Acer Aspire card reader not acknowledging SD card
go to Wal-Mart or K-Mart and such, you can get a SD reader/ writer (such as Targus, about $9 USD, what I use) and put your SD card into it, then plug into USB (USB 2.0 is current standard, but will work with USB 1.1, just slower). PC will ask if you want to play/record from/to the removable drive, select "take no action" then go to the "my computer" icon (or what ever you have named it) double click the drive letter for the flash/SD card (E,F,G etc.). open the file folder that you want to copy from <usually something like "100MEDIA" or such> (I STRONGLY recommend that you "COPY FILE(S)" and NOT "move file(s)" as that if something crashes you still HAVE the orig. files) select to copy to the correct drive letter/ file name(s) and PLEASE remember to "remove hardware safely" or you could KILL the files and/or the drive(s) that you were using. (did that TWICE before I realized what I was doing wrong). good luck!
SOURCE: aspire 5610z card reader doesnt show up. Vista home premium
Did you ever solved your problem? I noticed the above response is just a spam ad.
I have same problem with Aspire 3680. I recently replaced the HDD and reinstalled Vista Home, all drivers from Acer has been loaded. I even updated the BIOS, updated Vista service packs and all patches.
Sent email to Acer, but of course they want $60 per 1/2 hour. And from the past experience it will take about 2 hours on the phone. Also they have no support forum, and support sucks.
So I'm still stumped. This SD problem with Acer is the only one I couldn't resolve of all brands I've worked on.
