Question about Dometic Refrigerators
Our refergertor with stop working and will not change over to gas. will work about 5 days and will stop
When taken back to the dealer they say they can't find anything wrong but when we get back home it works for 5 days and stops and will not change to gas
5 Related Answers
Anonymous
SOURCE: Samsung side by side refrigerator not working
I am somewhat of a fix-it guy and here is my take....I also have the same refridge with other problems, and have done alot of research and discussions with the local repair techs and Factory rep. Here we go: The Samsung models are very prone to problems arising from power fluctuation's that fry the motherboards. One problem may be that the defrost circuit fails and the unit freezes up causing a lack of cooling and loud banging of the compressor. To run a diagnostic of the unit, you need to press both power freeze buttons for 10 seconds beeps will sound and release, the dashes on the display showing if any circuits are bad.(self diagnostic) This is what the service guy will do then come in with the part and replace. With a bad board, the diagnostics reveals no problem and the service agent will just start replacing parts, at your expense! Also the part #'s will show discontinued but they just changed parts #'s.. Be careful, my dealer said all parts were no longer available....he was wrong! Motherboards are a bear, I believe my model has 3!Most techs are not familiar with Samsung and will not be able to correctly diagnose the problems, mine came out and said it! "We do not Know and the factory will not give us any idea what the problem is" We're sorry! That was 3 month ago, and now I have a beautiful yard fixture! a $1400.00 yard fixture!! hope this helps someone..
Posted on Sep 06, 2007
Anonymous
  • 700 Answers
SOURCE: kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Posted on Jan 12, 2009
Anonymous
SOURCE: 1998 Buick Park Ave Speedometer stopped working.
Found the problem with the speedometer on my Buick. When you use the magnet to fix the gas gauge, will can and may affect your speedo. So use the magnet trick on it as well. Appears that the manufacturer didn't think about the needles being able to swing past the magnet they have set up in the gauges. Should have put a stop pin on the gauges.
Posted on Jan 28, 2009
Anonymous
  • 316 Answers
SOURCE: My speedometer and odometer stopped working
Your speed sensor has failed. The vehicles speedometer is not cable controled, it's controled by a sensor in your transmission. It's a easy fix, but the new sensor is about $80 to $100 depending on where you get it.
Posted on Apr 28, 2009
Anonymous
  • 326 Answers
SOURCE: Petz 5 not working.
Right-click on the Icon > Go-to Properties > Click the "Compatibility" tab > Click the check box next to "Run this program in compatibility mode for:" and select Windows 98 or Windows XP if available.
You may need to disable visual themes or other options.
Hit apply once you are finished configuring.
Posted on May 07, 2009
How can my back truck door instantly stop working?
You really can't blame them. Perhaps they left the door up for an extended period of time. There are struts filled with a gas charge that hold the heavy door up when opened. Maybe the gas has leaked out, and you will have to replace them. It's a pretty easy job, and they should not be too expensive, if you go to a parts store and not the dealer. Dealer prices are way beyond aftermarket replacements from a parts store.
2012 M37X intermittant failure to accelerate from stop,must put car in neutral and then D for vehicle to move.
How is it you have the issues & the dealer never drives it,
to experience the same thing you are?
They are jerking you & don't care to resolve
Either leave it there,try a different dealer or have the
factory rep come & work on it
1helpful
Gas Gauge does not work - Full when going come to stop light goes to "Need Fuel" When tank has just been filled with gas. should it be taken to the dealer or local mechanic?
fuel sending unit inthe tank acting up thse models have susceptical of sulfar from gas building up on the unit u can try chevron with techron fuel cleaner in the tank wait a few days see if that help if not not u need new fuel sending unit
1helpful
Hi, I gave my husband a cartier Panther about 7 years ago and he totally hates the watch because it never works. We have taken it to get checked out at jewelry stores but the people always tell us is the...
The most reliable solution is to send it back to Cartier.
They pride themselves on quality and if you complain loud enough, they may jump into action, although if you had batteries put in by anyone but one of their approved dealers, they may prove difficult.
(If it has a balance wheel, then it sounds like a mechanical adjustment may be all that is needed).
Oven doesn't work
Looks like it's time to put your oven down and adopt a new one. (Taps plays softly)
Aug 15, 2009 • Ovens
Engine light comes on and off once in a week.sent to dealer and they change oxygen sensor ($350)didnt work.my regular service to dealer is done on time. I also top up my gas evry day to avoid condensa
Hi, first off don't ever top off your tank I don't know who told you to do this but this is a bad thing. This by itself will cause your engine MIL to come on most likely with a code PO455 large evap system leak. by topping off your tank you are installing a problem on your own vehicle what happens is as the gas heats up it expands normally there is enough room at the top of the tank to stop overflow, but when topped off it overflows into the charcoal canister and starts leaving a caron buildup in your granulated charcoal and will render it useless and a replacement will be necessary. also make sure you clean your gas cap off very well with alcohol. As this by itself can cause your MIL to turn on intermittently and set a PO442 small evap leak code.
Heater and lights not working
i to have an oldsmobile intrigue mine is a 2001 i heard remote starts can really mess a car up this one is tricky **** it could be bad wiring since the remote start have your wiring looked at then if needs replacing replace it fast before any more problems occor
2answers
Engin light stays on in my toyota corolla
the car has been back to the dealer 4 times for the same problem. First time they claimed that they replaced malfunction tank by-pass vsv and codes mentioned are P0440, P0441 and P0446 that were malfunction. the second time they connected the car to their computer and re-scan the vehicle and told us that everything is working fine and the engine light is off, but after one day the light came back and the car went back to the dealer for the third time and now they claim that the problem is from charcoal canister and has to be changed. also after the second visit as soon as i got in my car i could small gas and it hasn't gone away and the dealer says they did nothing wrong and all the problem is from the canister. we really don't know if we can trust what they say.
I have a 2007 BMW 750li. It has about 21000 miles on it and we use high test gas in the car. Over the last few months it has started jerking when you stop and your foot is on the brake. It has also started...
This might actually be a software issue in the car. It can be taken care of at the dealer with re-programming. Its best to leave it for a few days because drivability concerns such as these can be the hardest to pin point. Best of luck and please let me know if anything changes.
Refrigerators Logo
Top Dometic Refrigerators Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Jay Finke
Jay Finke
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
