Pool & Spa Logo
Anonymous Posted on Feb 15, 2013
How to drain Vita Powerworks 504 Spa
How many drains does a Powerworks 504 have & where are they?
US Parts Center
Level 3:
  • Master 719 Answers
  • Posted on Feb 19, 2013
US Parts Center
Master
Level 3:
Answers
719
Questions
0
Helped
284271
Points
1972
Under the skirt somewhere close to the spa pack us usually a drain or some sort. they usually look like a 1/2" hose with a tiny 1/2" twist valve on the end of the tubing.
Rod
US Parts Center
888-521-6183
2answers
I need the wiring schematic for a 2003 vita spa l200 control box
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj-5PWiyqODAxXrkIkEHTTpBUAQFnoECBEQAQ&url=https%3A%2F%2Fwww.thespaworks.com%2Fsites%2Fdefault%2Ffiles%2F2003_3-04_vita_spa_l200_-l200c_owner_manual_0.pdf&usg=AOvVaw3lpf80iK2OccvLM1dX_6n2&opi=89978449
How to drain Vita Powerworks 504 spa?
Typically each spa will have one drain hose down with a valve close to the control box behind the spa skirting.
Rod
US Parts Center
888-521-6183
Feb 15, 2013 • Pool & Spa
Winter closing instructions
Winterizing your Spa or extended period shutdown If you don't have plans to use your spa during the winter months, you should drain it completely well before the temperatures get low enough to produce a hard freeze.
Hot tubs that are heavily used by bathers should be drained every 3 - 4 months. When it's time to drain, either drain to a sanitary sewer or use the water for lawn irrigation. Make sure no chemicals have been added for at least 48 hours before draining.
Water in spas filled with sprayed foam insulation will still freeze if not heated. Finding and fixing leaks in that foam is a nightmare! These recommendations could potentially save you a lot of money!
These basic steps will ensure safe, effective shutdown of your spa for the winter months or any other extended period with out use. Factors such as spa installation, location, type will affect the steps and procedures.
Use these recommendations as a guide.
  • Disconnect the spa from the power supply.
  • Open the drain valve (if installed) or pump out all water.
  • Remove the filter cartridge(s). Clean & store in a dry place. (FILTER FLOSSER)
  • If possible attach a wet/dry (shop) vacuum (capable of blowing air as well as vacuuming) to the hole in the bottom of the filter housing.
  • Using the blower function, blow out any excess water through the plumbing system - allow a good 5 minutes of blowing time.
  • Use the shop vac to remove any water blown through the jets into the tub or towel dry any remaining water from the spa, until it is completely dry.
  • Leave drain & gate valves open, if you have rodent issues we recommend MOUSE AWAY.
  • Close the spa cover and fasten with tie down safety locks.
This is not a job you want to do in freezing conditions, give yourself enough time. Make every effort to ensure ALL of the water is removed - including remnants in the pump lines and jets.
These are common sense steps always be safe around water and electricity.
Sep 20, 2012 • Pool & Spa
Is there a better way of draining the spa,we have the manual and it refers to quick drain but there is no information anywhere in the manual regarding this or any other way of draining the spa.We are using...
Behind one of your access panels there is a pvc tube that has a square end on it that would the place to drain unscrew that plug and let er rip. Good Luck....
Apr 19, 2011 • Garden
Yes rats squirrells drain flies pine cones surely
get a bb gun an some rat traps and some raid, if you live in the country this going to happen find out where they are coming in at and close it off and unless you built your house out of "nuts" it shouldnt be problem to keep such retarded animals at bay
Need manual for a vita bijou hot tub
Vita Spa is now out of business, so contacting the factory isn't a option. You can try googling for an online manual download. They usually cost between $10 and $15.
1helpful
I need to drain my vita spa but don't know how. Is there a simple way to do this?
Simple way is put a hose in it and syphone the water out. You will have to fill the hose with water, put your hand over the end and get that end out of the tub to a place lower than the water level, let the water go ...
Next best is get a pump and pump it out ... costs $
There is probably a drain on the bottom ... they are generally pretty slow.
Jun 10, 2010 • Garden
2answers
Hot tub maintenance
there will be the same amount of basic maintenance on either spa. The difference will be in water chemistry. you definitely want an ozone generator on either spa. Both are awesome Mfg of spas. they both have been around since the 1980's
Ozone will keep the water cleaner, fresher smelling and reduce the total amount of traditional chemicals used in any hot tub.
There are many other solutions for taking care of water chemistry out there without using the traditional types.
some are all natural.
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
